Preferences suggestions
12 of 12 messages available
Preferences suggestions Michael J. Hammel 03 Mar 18:45
  Preferences suggestions Raphaël Quinet 03 Mar 19:57
   Preferences suggestions Christian Rose 03 Mar 22:40
   Preferences suggestions Michael J. Hammel 04 Mar 16:51
  Preferences suggestions Sven Neumann 04 Mar 13:10
   Preferences suggestions Michael J. Hammel 04 Mar 17:23
    Preferences suggestions Sven Neumann 04 Mar 17:48
     Preferences suggestions Michael J. Hammel 04 Mar 18:37
      Preferences suggestions Sven Neumann 04 Mar 19:19
  Preferences suggestions Nick Lamb 04 Mar 15:43
   Preferences suggestions Sven Neumann 04 Mar 16:19
  Preferences suggestions Guillermo S. Romero / Familia Romero 04 Mar 19:51
Michael J. Hammel
2003-03-03 18:45:16 UTC (about 22 years ago)
Sven asked for some feedback on the Preferences dialog. Here is my take on it. I'm sure I can handle many of the changes, but I haven't looked into the code yet. If you need me to make the changes (once they're approved) let me know. I won't be able to submit much before the 21st cuz I'll be on holiday, however, and assuming I haven't found another job by then.
Comments on the Preferences dialog:
0. General comments a. Why is the default font for labels so small? My eyes are old!
b. Lists should not include sublists that have only a single item. If you have sublists, there should be at least two entries in that list. Otherwise, merge the sublist into the main list page.
c. I really think you need to call the "Image Window" the "Canvas Window". "Image" is too generic - it's used for thumbnails, layers, etc.
d. US English vs UK English spellings: "Behavior" in Interface page, "Behaviour" in Image Windows page.
e. Lots of tooltips say "When set to YES..." when referring to toggle buttons or option menus that don't have a "YES" option. These need to be updated.
1. Page: New Image a. Should it be "New Image" or "New Canvas"? Is the canonical name for that window a Canvas? That's what I've been calling it for years (even in my books), but maybe I've been wrong.
b. Why isn't "Indexed" included as a default image type option?
c. Why a "dpi" *AND* a Pixels/inch setting? The bottom set, with the "Pixels/inch" options menu should be enough. "DPI" should be part of the text header for this frame.
d. Why do we have a "maximum image size?" Shouldn't GIMP handle any image size? Should this value be set as a percentage (rounded to a power of 2) of installed memory?
2. The Comment page should be integrated into the New Image page as a 2nd page in a notebook.
3. Page: Interface a. We shouldn't use frames with a single element - frames should enclose two or more elements. Dialog behavior and Menus should be merged with the Window Positions frame and retitled "Windows and Menus"
b. Dialog Behavior toggle has tooltip that says "When set to YES...". This should be changed to "When enabled...". Also, "per display" should be changed to "per image window" (or "per canvas window").
4. Page: Help System a. Remove frames.
b. Why aren't Mozilla and Galeon included in the Help Browser list?
5. Tool options should be merged with another page, perhaps the Interface page, until more default options for Tools are provided.
6. Despite having few configurable options, the Input Devices page should stay the way it is. It may have more options - I don't have any input devices available to test that.
7. Page: Image Windows a. Make this page a notebook, with the following pages: 1. Appearance / Canvas padding color 2. Zoom / Resize, Pointer Movement
b. Merge Title & Status page as a 3rd notebook page in the Image Windows page.
c. Title formats should be explained - what do each of "f", "p", etc. mean?
8. Merge the Display and Monitor pages. They're similar enough and can fit on one page.
9. Page: Environment a. Move Environment to the top of the list. It is more general than the other options (except the Folders) and it has no sublist. It's easier to see that it's a top level item this way as opposed to thinking it's part of the Interface sublists.
b. Maybe it's me, but I think the icon for Environment ought to be trees and a sun, not a nerdy IC.
c. The tooltip for "File->Save" is incorrect. It should be updated to match the current options menu text.
d. "Size of thumbnails Files" should probably be "Size of thunbnail Files".
10. Page: Folders a. What do the green dots in the "Folders" page represent?
b. Put the "tenp dir" and "swap dir" in frames. Title each "Location for temporary files" and "Location of swap files". Change the "..." to "Select a directory". This will spread this page's contents out a bit. It looks crowded right now.
Raphaël Quinet
2003-03-03 19:57:39 UTC (about 22 years ago)
And here are my comments on (some of) your comments... I agree with most of your suggestions, so I only quoted the parts on which I had something interesting to say.
1. Page: New Image
Creating a new image in indexed mode would require a default colormap. We could add an option for selecting among the available color palettes, just below the option for selecting the default image type.
Because you want to be able to set the default unit? I prefer millimeters instead of inches.
The label for this option should be changed to "Maximum Image Size Before Warning". This is longer, but this is a better description of what it does. I don't think that it is necessary to set it as a percentage of installed memory.
And in the future, it should be able to set more than the default comment. It should also set the default value for other properties used by EXIF and XMP/IPTC metadata. See also: http://bugzilla.gnome.org/show_bug.cgi?id=56443 (EXIF) http://bugzilla.gnome.org/show_bug.cgi?id=94416 (XMP/IPTC) http://bugzilla.gnome.org/show_bug.cgi?id=61499 (editor) I still have to work on that...
This is a FAQ. This gets asked so frequently that we should seriously think about adding a whole paragraph of text in this dialog. Also, "Netscape" should probably be "Netscape-compatible" or something like that. The options should also be different for the Windows build.
If this option gets its own page/tab, then we could explain this in the page. Otherwise, there should be a prominent link to the help page.
Hmm... No, because they are dealing with different things. If the Display page is merged with something, it should be merged with some of the Image Windowse pages. If this is a notebook, then it would be appropriate to have it as a separate tab in that section.
-Raphaël
Christian Rose
2003-03-03 22:40:33 UTC (about 22 years ago)
mån 2003-03-03 klockan 19.57 skrev Raphaël Quinet:
The default here (US/metric) should probably be a function of the locale, as that information is already available in the locale. Reported now as http://bugzilla.gnome.org/show_bug.cgi?id=107497.
Christian
2003-03-04 13:10:02 UTC (about 22 years ago)
"Michael J. Hammel" writes:
we use the default GTK+ font size and it is up to you to configure it.
the strings used for the tooltips are as well used for the gimprc man-page and the comments in the system-wide gimprc. In my opinion the strings are acceptable but if someone wants to change them, please keep in mind that they are not only used as tooltips. An alternative would be to use only check-buttons for boolean values.
I grepped preferences-dialog.c for prefs_boolean_option_menu_add() and I only found two settings that use an option menu for boolean values. Are these lots??
1. Page: New Image
That page really refers to settings for the "New Image" dialog.
because we don't allow to create indexed images from scratch. You need to create a RGB image anc convert it to indexed later. The reason is that we don't want to clutter the New Image dialog with Palette settings.
I always found it very convenient to have both.
That setting is explained in the tooltip. It could probably be reworded. I don't think we want to base it upon installed memory since there is no proper way to determine the amount of installed memory.
the right half of the dialog is a notebook already and GTK+ doesn't like notebooks in notebooks that much. We could decide to make the comment textview smaller and add it to the New Image page.
I like the idea of using "When enabled..." instead of "When set to yes..." since that should work fine for the manpage as well.
because of http://bugzilla.gnome.org/show_bug.cgi?id=51632
IMO the Contigous Region setting can die now that we have (or almost have) persistent tool options.
unfortunately it can not stay. If you had any input devices you'd have found that dialog is pretty much cluttered and that GIMP crashes if you use GTK+-2.2:
http://bugzilla.gnome.org/show_bug.cgi?id=104423
There's another report about this very page which is IMO valid as well:
http://bugzilla.gnome.org/show_bug.cgi?id=95446
see my comment above. We can have multiple pages grouped in the tree view on the left but no notebooks inside a notebook.
they are explained in the gimprc man-page.
do you think so? IMO the transparency setting doesn't belong there at all. It fits better to the Canvas settings but then it affects layer and image previews as well (but that could be silently ignored).
actually, I'd rather get rid of this setting. Does anyone use anything but the default value ("no") for "trust-dirty-flag" ?
10. Page: Folders
they indicate that the file/folder exists. Yes, they suck but it's the default GTK+ "yes" icon.
hmm, the "..." button is part of the GimpFileSelection widget:
http://developer.gimp.org/api/1.3/libgimpwidgets/GimpFileSelection.html
If we'd change it, we'd also change all the other Folders pages since they use it as well.
Salut, Sven
Nick Lamb
2003-03-04 15:43:28 UTC (about 22 years ago)
All user interface parts of The GIMP should be US English with any parts translated into British English by using gettext and locale en_GB. Since our resources are limited, the manual & documentation should be US English throughout.
It's possible if your locale /is/ set to en_GB that you're just seeing a partial translation, which you can confirm by running 'LC_ALL=C gimp'
Nick.
2003-03-04 16:19:07 UTC (about 22 years ago)
Nick Lamb writes:
right. There has been work on translating the help as well. At the moment however we should first concentrate on getting help finished for 1.3 in US english.
the string was indeed spelled incorrectly. I have now fixed some of the more obvious things Michael suggested:
2003-03-04 Sven Neumann
Based on suggestions by Michael J. Hammel :
* app/gui/preferences-dialog.c: use US english spelling, fixed a typo.
* app/config/gimprc-blurbs.h: rephrased some blurbs so they fit better as tooltips.
Salut, Sven
BTW: The en_GB translation seems pretty much abandoned. Perhaps someone wants to bring it uptodate ?
Michael J. Hammel
2003-03-04 16:51:53 UTC (about 22 years ago)
More feedback, just for discussion sake.
That's fine, but the question is why isn't "Pixels" included as one of the unit options? In other words, do we need a Pixels line *and* a separate unit line? IMHO, I think not *if* you're targeting home users. If you're targeting more professional artists, then you might want both.
I raised this one after my wife, who is a budding Photoshop artist, found she liked GIMP for certain tasks and was confused by this option. She is only beginning to understand the issues related to DPI. Photoshop hides those issues quite well for her.
The problem is one of perception to novice and less experienced users. This text makes it appear that you have limits on the size of the image you can handle. Novice and inexperienced users won't understand how big 32MB is in relation to what they are working on because few have a good grasp of the whole DPI issue.
If this setting is meant as an upper bound before a warning is presented stating you have limited resources, than it should read something like:
"How much memory to use before displaying a warning regarding low resources:"
Keep in mind that this dialog has lots of free space in various places. Long text labels should not be avoided if they help explain the configurable option.
That said, if you're target audience is more experienced users then this label probably isn't an issue.
Sven pointed to the Bug report on this. I suggest changing "Netscape" to "External" so the terminology in the options menu is a more consistent and have the tooltip mention that the browser must be Mozilla (which I assume is what is meant by "Netscape") compliant and reference the documentation (re: man page) that defines what browsers are compliant.
Michael J. Hammel
2003-03-04 17:23:52 UTC (about 22 years ago)
Why? It would be easy for us to provide a font size setting and stuff it into a GIMP-specific gtkrc file, letting the user know that the changes will take effect the next time GIMP is started. In fact, that's one of the usability features of GTK+ (even if few people talk about it as such).
GTK+ does let the user configure lots of things on their own. But that doesn't mean applications shouldn't provide user friendly options to handle it for the user. (That's an arguable opinion, of course.)
Is this value meant to be on a per Image Window basis or is it global to all open images? That isn't clear in the tooltip. If its per image, a short addition to the tooltip would cover this, I think.
Hmmm. Looking at it I'd say the notebook was used to address layout issues and not for its page features. If notebooks in notebooks don't work well (I actually don't think I've ever tried that in my apps), then the top level notebook should be replaced with something else so that a notebook at the page level could be used. The layout issues can be solved with other GTK+ widgets. That's just my opinion on dialog design, of course.
Changing the textview to be smaller and moving it would address my original comment about this page. In fact, it's a perfectly good solution.
I mentioned something about this in the reply to Raphael.
I wish I did have some input devices. Finding Wacom tablets that I can afford (and are worth the money - not that little Pen Partner thing) is hard to do. Do any other (non-Wacom) tablets work?
There should probably be something in that page that references that man page then. Probably in a tooltip, though a text label with a short description and reference at the bottom of the page would work just as well.
From a non-technical users standpoint these two are very similar even
if, technically, they are very different. To the end user, they are configuring options here that define what they see and how they see it in a program-global way.
The transparency belongs here because it's global and not on a per image window basis. You might even merge these two into the Environment page though I think that would be too much clutter for Environment.
10. Page: Folders
You have the space in this page so I'd remove these icons and replace them with a text label that changes based on whether the directory exists or not. A "Create" button would be useful here as well. The text label will also help spread the contents of this page out a little, making it feel less cluttered.
Bummer. It would be nice if that button's text was configurable.
2003-03-04 17:48:57 UTC (about 22 years ago)
GIMP is probably not the only GTK+ application people are using and setting the font size in the GIMP gtkrc would make it the only GTK+ application that doesn't follow the font settings from the desktop enviroment. This is IMO a very bad idea.
it is of course per image. The only reason we have introduced this is to prevent the user from accidentally entering wrong values into the New Image dialog, causing GIMP to crash because it cannot allocate enough memory for a 256m x 256m image.
I don't see a way of doing such a dialog layout w/o using a GtkNotebook for the right part. At least not without the dialog resizing on page switches. I'm open for your suggestions however.
Salut, Sven
Michael J. Hammel
2003-03-04 18:37:49 UTC (about 22 years ago)
Perhaps. However, I'm running GNOME with GIMP 1.3 and the fonts for text labels don't match at all - GIMP's are very small, GNOME's are fine. I haven't adjusted any font settings for the desktop and I have no .gtkrc or .gtkrc.mine in my home directory.
Anyway, its a design decision. You won't please everyone. And I can, of course, adjust the settings myself.
Well, it sounds like the notebook is enforcing a minimum size to the dialog for you. You'd have to do this manually by determining which page was the largest. I'm not positive but I think you can do this by realizing each page first, checking the parent widgets width and then setting the dialogs width appropriately before calling gtk_widget_show() (not sure if this has changed in GTK2.0, however).
Alternatively, you could set the width of the folder lists or the comment textview to be the widest page and force the dialog not to shrink beyond what allows those to show completely. I'd fiddle with Glade for a bit to find a dialog layout that worked this way, then implement the widgets in the preferences dialog (with our without using Glade's code).
The trick is to find the widgets that let you do what the notebook is enforcing for you.
All that said, considering that the only place you might have really needed this can be replaced by just resizing the comment textview and placing it on another page, I'd just forget the notebook issue for now. It's easier to just move the textview and I'm sure there are more pressing issues that you could work on.
2003-03-04 19:19:24 UTC (about 22 years ago)
do you run gnome-2.x? If not, you shouldn't be surprised that the settings don't take effect. The file ~/.gtkrc is irrelevant for GIMP-1.3 since it uses GTK+-2.x. You should look for .gtkrc-2.0. And then there might be XSettings which override the value found there.
eeek, what an evil idea. You can of course get this right for your theme and font settings but it will never ever work for everyone.
Salut, Sven
2003-03-04 19:51:20 UTC (about 22 years ago)
mjhammel@graphics-muse.org (2003-03-03 at 1145.16 -0600):
Comments on the Preferences dialog: 0. General comments
Uh? If I understand you, what you have is to change your font, cos the font size looks like the default one, and in some places just bigger, but I do not see where it is smaller than the default one. So I do not get it, or the problem is elsewhere.
1. Page: New Image
No, DPI should not be in the header, cos if you set the menu to pixel/mm, you are not talking about DPI anymore. You are always talking about resolution. Removing the top one could be an option, keeping is another, and this one is nice for those that want to use see DPI (typical unit for printing) and at the same time get an unit they can imagine quickly (all non inch users), which I think is a noticeable group of people. It is a tricky area for those who have to mix the local units with the graphic units.
Hehe, the talk about disk cache and such again. ;] BTW, it is not a hard limit, just a warning limit, so errors are corrected faster (ie, not waiting your computer to swap tons of MBs). The problem is the label, probably.
The transparency thing is more an Image feature (like padding colour). But the 8 bit part could be placed somewhere with other Monitor things.
Think in other languages too, maybe in those the correct translation of computer environment has nothing to do with trees. And from looking at the contents, a chip makes sense, it lets you configure memory things.
10. Page: Folders
"OKness" of the path. If path is wrong, it appears red.
GSR
