Any known bugs with Dissolve blend mode in 1.2?
        I just noticed what may be a bug (I don't see a bug report on it yet,
though).  The dissolve blend mode doesn't appear to work consistently.
In one case the application of a Dissolve blend mode produces the spotty
effect you'd expect with 50% opacity.  In other cases, it just produces
the effect you'd expect with the opacity at 50% under Normal blend mode.
For example:
1. Background layer (no alpha channel):
Make a square selection. Do a bucket fill with Bucket Tool options
opacity set to 50% and Blend mode set to Dissolve.  Result:  spotty
bucket fill (as expected).
2. Background layer (no alpha channel):
No selection.  Do a bucket fill with Bucket Tool options opacity set to
50% and Blend mode set to Dissolve.  Result:  smooth fill that is
partially transparent (ie it's not spotty).
3. 2nd layer (with alpha channel):
opacity set to 50% and Blend mode set to Dissolve.  Result:  smooth fill
that is partially transparent (ie it's not spotty).
4. 2nd layer (with alpha channel):
Additionally, the layer blend mode, when set to dissolve, doesn't seem
to ever produce the expected spotty effect.  It appears that dissolve
only works when applied with painting tools within a selection and on a
layer with no alpha channel.
Is this a known problem?  Am I just using it incorrectly?  I can write a
bug report for it if its new.  I just wanted to check first to be sure.
I'm using 1.2.3 and have not tested this against the 1.3.x branch.
