Gimp-print mainline
Gimp-print mainline Robert L Krawitz 14 Feb 02:13
  Gimp-print mainline Sven Neumann 14 Feb 10:55
   Gimp-print mainline Robert L Krawitz 14 Feb 13:06
    Gimp-print mainline Sven Neumann 14 Feb 13:31
     Gimp-print mainline Robert L Krawitz 14 Feb 14:02
     Gimp-print mainline Tor Lillqvist 15 Feb 03:05
Robert L Krawitz
2003-02-14 02:13:51 UTC (about 22 years ago)
Gimp-print mainline
I'm getting ready for a 4.3.9 release. This release offers a lot of new functionality in the GIMP plugin that really needs to be played with to understand (in particular, all the curves you could want).
Tyler, can you take a crack at building an OS X package for this? The emphasis is completely different from the 4.2 releases; 4.3.9 offers nothing new of interest for general purpose printing from CUPS. The idea here is to build a package with a GIMP plugin that can be used with the OS X GIMP port, so that all of the color hackers can get their toys to play with.
2003-02-14 10:55:24 UTC (about 22 years ago)
Gimp-print mainline
Robert L Krawitz writes:
what exactly do you mean when you speak of "the OS X GIMP port" ?
Salut, Sven
Robert L Krawitz
2003-02-14 13:06:21 UTC (about 22 years ago)
Gimp-print mainline
Date: 14 Feb 2003 10:55:24 +0100
> I'm getting ready for a 4.3.9 release. This release offers a lot of > new functionality in the GIMP plugin that really needs to be played > with to understand (in particular, all the curves you could want). >
> Tyler, can you take a crack at building an OS X package for this? The > emphasis is completely different from the 4.2 releases; 4.3.9 offers > nothing new of interest for general purpose printing from CUPS. The > idea here is to build a package with a GIMP plugin that can be used > with the OS X GIMP port, so that all of the color hackers can get > their toys to play with.
The Fink package.
2003-02-14 13:31:20 UTC (about 22 years ago)
Gimp-print mainline
The Fink package.
We usually try to avoid to use terms as "the Win32 GIMP port" or "the OS X GIMP port" since GIMP is multi-platform and there are no ports to other operating systems. Everything is built from the same source (well, of course there is a tiny bit of platform-dependant code). If it turns out that any changes need to be made in order to build The GIMP on a particular platform, this change should be folded back into the GIMP source and should if possible not be maintained outside the main source tree.
I'd appreciate if you would try to respect this arrangement in public correspondance since it has already caused some misunderstandings in the past.
Salut, Sven
Robert L Krawitz
2003-02-14 14:02:19 UTC (about 22 years ago)
Gimp-print mainline
Date: 14 Feb 2003 13:31:20 +0100
Fair enough. That wasn't my intention; "package" would indeed be a more accurate description.
Tor Lillqvist
2003-02-15 03:05:29 UTC (about 22 years ago)
Gimp-print mainline
Sven Neumann writes:
> We usually try to avoid to use terms as "the Win32 GIMP port" or "the > OS X GIMP port" since GIMP is multi-platform and there are no ports to > other operating systems.
Isn't it the terms "version" or "project" that should be avoided, not "port"?
--tml
