gimpbilinear and alpha
gimpbilinear and alpha David Necas (Yeti) 07 Feb 17:18
David Necas (Yeti)
2003-02-07 17:18:33 UTC (almost 23 years ago)
the gimp_bilinear_rgba () function (libgimpcolor/gimpbilinear.c) handles alpha channel as if Gimp used premultiplied alpha. Since all Gimp core uses separated alpha, I suggest the attached patch (against CVS HEAD). This patch itself seems to fix alpha handling in two plug-ins using gimp_bilinear_rgba ():
#72876 Incorrect RGBA resampling in Map Object plug-in #105796 Incorrect RGBA resampling in Lighting Effects plug-in (this one may be not fully fixed)
Beside that all the remaining functions in gimpbilinear operate on individual channels (colors) and not pixels. Plug-in authors using them hardly can handle alpha blending correctly. IMHO functions operating on whole pixels are needed more than the existing ones (though they are also useful).
Yeti
--- gimp.orig/libgimpcolor/gimpbilinear.c 2002-11-20 22:29:15.000000000 +0100 +++ gimp/libgimpcolor/gimpbilinear.c 2003-02-07 16:34:55.000000000 +0100 @@ -173,6 +173,7 @@
gdouble m0, m1;
gdouble ix, iy;
+ gdouble a0, a1, a2, a3, alpha;
GimpRGB v;
g_assert (values != NULL);
@@ -188,33 +189,41 @@
ix = 1.0 - x;
iy = 1.0 - y;
- /* Red */
+ a0 = values[0].a;
+ a1 = values[1].a;
+ a2 = values[2].a;
+ a3 = values[3].a;
- m0 = ix * values[0].r + x * values[1].r; - m1 = ix * values[2].r + x * values[3].r; + /* Alpha */
- v.r = iy * m0 + y * m1;
+ m0 = ix * a0 + x * a1;
+ m1 = ix * a2 + x * a3;
- /* Green */
+ alpha = v.a = iy * m0 + y * m1;
- m0 = ix * values[0].g + x * values[1].g; - m1 = ix * values[2].g + x * values[3].g; + if (alpha > 0)
+ /* Red */
- v.g = iy * m0 + y * m1;
+ m0 = ix * a0 * values[0].r + x * a1 * values[1].r; + m1 = ix * a2 * values[2].r + x * a3 * values[3].r;
- /* Blue */
+ v.r = (iy * m0 + y * m1)/alpha;
- m0 = ix * values[0].b + x * values[1].b; - m1 = ix * values[2].b + x * values[3].b; + /* Green */
- v.b = iy * m0 + y * m1;
+ m0 = ix * a0 * values[0].g + x * a1 * values[1].g; + m1 = ix * a2 * values[2].g + x * a3 * values[3].g;
- /* Alpha */
+ v.g = (iy * m0 + y * m1)/alpha; +
+ /* Blue */
- m0 = ix * values[0].a + x * values[1].a; - m1 = ix * values[2].a + x * values[3].a; + m0 = ix * a0 * values[0].b + x * a1 * values[1].b; + m1 = ix * a2 * values[2].b + x * a3 * values[3].b;
- v.a = iy * m0 + y * m1;
+ v.b = (iy * m0 + y * m1)/alpha; + }
return v;
