Why modules interface?
3 of 4 messages available
DE924A789E3C124F8C8A319F273... 07 Oct 20:21
  Why modules interface? Austin Donnelly 22 Jan 10:54
   Why modules interface? Michael Natterer 22 Jan 16:59
    Why modules interface? Kai-Uwe Behrmann 22 Jan 17:30
Austin Donnelly
2003-01-22 10:54:44 UTC (about 22 years ago)
I want to add some features (changeing the gamma of the display ...) to filmgimp.
There already is a module called "cdisplay-gamma" which can do this. You don't need to write any code, just use this pre-existing module.
However, I'll still answer the rest of your questions:
I liked to implement this as removeable plug-ins but they are (as far as I expect) not selfcalling. The application I'm planning needs to start instandly with filmgimp.
By "selfcalling", I assume you mean that it starts automatically.
1. Is the modules interface the best way for this?
Yes, because changing the gamma of the display requires tight integration with the display code.
2. What are all the differences between plug-ins and modules?
Plugins run in their own process, so if there is a bug in a plugin, it should not crash the gimp. Modules run in the same process as the main gimp, so a bug in the module can crash the entire thing.
The only reason you should use a module is if your code needs to be called so frequently that the overhead of being in a separate process is too much. Or, if you need to share state with the main gimp application (eg because you are extending the main UI directly, like the colour selectors do).
Hope this helps, Austin
Michael Natterer
2003-01-22 16:59:40 UTC (about 22 years ago)
"Austin Donnelly" writes:
The best idea IMHO would be to drop this silly film-gimp code duplication and help coding on gimp 1.4 (which already has this feature).
ciao,
--mitch
Kai-Uwe Behrmann
2003-01-22 17:30:17 UTC (about 22 years ago)
Am 22.01.03, 16:59 +0100 schrieb Michael Natterer:
Of course one programm would be fine for developing together. At the moment many people await the gimp-2.0 with gegl and 16bit, floats, cmyk, CIE Lab ...
Filmgimp is near to the above mentioned colordepths. Therefore I decided to programm for it.
ciao,
--mitch
regards
Kai-Uwe
