Resize bug in 1.3.10 (causes color changes)
Resize bug in 1.3.10 (causes color changes) Matthew Lewis 07 Dec 01:09
  Resize bug in 1.3.10 (causes color changes) Sven Neumann 09 Dec 12:10
Matthew Lewis
2002-12-07 01:09:45 UTC (over 22 years ago)
I discovered a bug with the resize tool.
* start with a white background and draw some black text on it. * select the black text with the rectangular select tool. * choose the resize tool and resize the text area.
The text will change colors (Typically it turns blue). Also, the selection box will sometimes leave artifacts on the canvas.
2002-12-09 12:10:56 UTC (over 22 years ago)
"Matthew Lewis" writes:
bugs should be reported using http://bugzilla.gnome.org/. This one however has already been fixed in CVS so there's no need to open a new bug-report for it:
2002-11-10 Michael Natterer
* app/core/gimpdrawable-transform.c (gimp_drawable_transform_paste): the transformed tile_manager has always an alpha channel, so use gimp_drawable_type_with_alpha() when creating a layer from it using gimp_layer_new_from_tiles(). Fixes bug #98053.
Salut, Sven
