OS/2 compatibility
Dreamworks, Shrek, and the need for 16 Bit Guillermo S. Romero / Familia Romero 01 Nov 18:27
OS/2 compatibility Robert L Krawitz 02 Nov 17:24
  OS/2 compatibility Sven Neumann 02 Nov 18:10
   OS/2 compatibility Robert L Krawitz 02 Nov 18:14
2002-11-01 18:27:11 UTC (over 22 years ago)
sven@gimp.org (2002-11-01 at 0211.09 +0100):
adjustments before the data is propagated down to 8bit? I was thinking of something like the levels tool. Do you think it would be possible to perform a reasonable first color adjustment only by looking at a histogram? In that case it should relatively easy to add that
It could be, yes, but I do not think a pure math way is the right way, images are "more white, no, less, tweak that".
functionality to some of the file plug-ins. Since this wouldn't need any support from the GIMP core (albeit perhaps some helper functions in libgimp and libgimpwidgets) this could happen for GIMP-1.4. What do you think?
I think it should be visual, a window with the image in 8 bit, and controls that decide how to get that 8 bit from the original 16 or 32. Basically black & white points and a curve. I say visual, cos it could mean what one does in the lab, but digital (load some copies, adjust each one at will, and mask and mix all the copies to get the final image).
PNG should be included in this family too, BTW. Any other format?
GSR
Robert L Krawitz
2002-11-02 17:24:56 UTC (over 22 years ago)
OS/2 compatibility
Is OS/2 compatibility (via #ifdef __EMX__) still a desired goal?
2002-11-02 18:10:46 UTC (over 22 years ago)
OS/2 compatibility
Robert L Krawitz writes:
a good question that also came to Mitchs' and my mind up lately when working on GIMP code. Does it work at all? Do we have OS/2 users?
Salut, Sven
Robert L Krawitz
2002-11-02 18:14:34 UTC (over 22 years ago)
OS/2 compatibility
Date: 02 Nov 2002 18:10:46 +0100
I suspect that the print plugin is broken. I've been doing some cleanup on the print plugin, and there's some code that just looks wrong. I'd rather get rid of it.
