i18n
i18n Karel Kulhavy 07 Jun 15:39
  i18n Sven Neumann 07 Jun 16:08
Karel Kulhavy
2002-06-07 15:39:47 UTC (almost 23 years ago)
i18n
When I set up Czech keyboard in ISO 8859-2 encoding in X (I can write czech letters in xterm) and run GIMP, make new image, text tool, filter fonts to get only the 8859-2 ones and try to write Czech chars into the text line, they are ignored.
If I don't filter it, it works.
Clock
2002-06-07 16:08:35 UTC (almost 23 years ago)
i18n
Karel Kulhavy writes:
some more details like the version of GIMP you are using would help a lot. This looks like it has already been reported as
http://bugzilla.gnome.org/show_bug.cgi?id=23226
or even
http://bugzilla.gnome.org/show_bug.cgi?id=79754
Could you please check if your problem fits into one of those bug-reports and probably add some comments to them. Or file a new bug-report if none of the existing bug-reports fit.
Salut, Sven
