Issue building Gimp from GIT
Issue building Gimp from GIT Steven P. Ulrick via gimp-developer-list 04 Jul 01:59
  Issue building Gimp from GIT Steven P. Ulrick via gimp-developer-list 04 Jul 02:14
  Issue building Gimp from GIT Ell via gimp-developer-list 04 Jul 07:11
   Issue building Gimp from GIT Steven P. Ulrick via gimp-developer-list 04 Jul 08:59
    Issue building Gimp from GIT Steven P. Ulrick via gimp-developer-list 04 Jul 09:04
     Issue building Gimp from GIT Liam R E Quin 04 Jul 13:24
2019-07-04 01:59:10 UTC (almost 6 years ago)
Hello, Everyone
I am running Fedora 30 and attempting to build, install & eventually run GIMP from GIT. It builds & installs without error. But when I attempt to run it I get the following:
[steve@afolkey2 bin]$ ./gimp-2.99 ./gimp-2.99: error while loading shared libraries: libjson-c.so.2: cannot open shared object file: No such file or directory
Obviously the error itself makes perfect sense. Fedora 30 has libjson-c.so.4, not libjson-c.so.2
So the question is, why does GIMP compile and install with libjson-c.so.2 not installed, but it won't run. I would assume that if a file that GIMP requires if it is not going to crash is not present, that GIMP would not compile. Also, what can I do to get this to work.
I know that I do not need to compile GIMP from GIT. I just enjoy doing it. I further understand that the issue could be with Fedora 30 or me.
Thank you,
Steven P. Ulrick
2019-07-04 02:14:24 UTC (almost 6 years ago)
On 7/3/19 8:59 PM, Steven P. Ulrick wrote:
Hello, Everyone
Now I feel better. I just installed GIMP from the official Fedora 30 repos and it crashes with the same error:
[steve@afolkey2 ~]$ /usr/bin/gimp /usr/bin/gimp: error while loading shared libraries: libjson-c.so.2: cannot open shared object file: No such file or directory
I wonder if anyone else running Fedora 30 is having this issue.
Steven P. Ulrick
2019-07-04 07:11:11 UTC (almost 6 years ago)
On July 4, 2019 4:59:10 AM GMT+02:00, "Steven P. Ulrick via gimp-developer-list" wrote:
Hello, Everyone
One of GIMP's dependencies was built against an older version of json-c. Probably libmypaint, but you can find out using lddtree. If you've built that dependency yourself as well (which is likely, otherwise we'd be hearing a lot more about it :) you need to rebuild it.
-- Ell
2019-07-04 08:59:42 UTC (almost 6 years ago)
Hello, Everyone
.2:
Obviously the error itself makes perfect sense. Fedora 30 has libjson-c.so .4, not libjson-c.so
.2
So the question is, why does GIMP compile and install with libjson-c.so .2 not installed, but it won't run.
a
Yeah, under Fedora 27, I had to compile libmypaint from source to get GIMP from GIT to build. Forgot all about it... Rebuilding now, having made the appropriate changes to get the non-F30 version of libmypaint out of the way. We'll see what happens.
The result is that the Fedora 30 version of GIMP starts perfectly. The version from GIT, recompiled following a "make distclean", does not work. It crashes with the same error.
2019-07-04 09:04:40 UTC (almost 6 years ago)
Hello, Everyone
.2:
.2
a
Hello, Ell
Spoke to soon. I logged out, logged back in and tried again, and it finally started. Strange, since I did "su - steve" in a terminal directly before I tried starting GIMP from GIT. In any even, I can begin rotating pictures from our recent trip to England...
Thank you for you help!
Steven P. Ulrick
Liam R E Quin
2019-07-04 13:24:44 UTC (almost 6 years ago)
On Thu, 2019-07-04 at 04:04 -0500, Steven P. Ulrick via gimp-developer- list wrote:
It sounds like you might be installing gimp and its depndencies into somewhere owned by the operating system; /usr/local is probably safe on Fedora (it isn't on Debian) but using a prefix like $HOME/opt is better. Then put a short shell script in your PATH that runs your local version gimp (mine is called "lgimp" for local gimp).
begin
I hope you had a good trip! Do you post pictures somewhere? :)
Liam (originally from the UK)
Click here to have the slave beaten.
