ANNOUNCE: GIMP 2.10.12 released
ANNOUNCE: GIMP 2.10.12 released Michael Natterer 16 Jun 14:09
  ANNOUNCE: GIMP 2.10.12 released Carmelo DrRaw via gimp-developer-list 16 Jun 20:32
Michael Natterer
2019-06-16 14:09:14 UTC (almost 6 years ago)
A few days late, but...
We just released GIMP 2.10.12, the sixth bugfix release in the stable 2.10 series.
As announced before, stable GIMP 2.10.x is open for new features that are not too invasive or change the API, and we got some good new stuff for you this time, too.
For a complete list of changes since 2.10.10 please see the "Changes" section below.
There is also a release announcement on www.gimp.org:
https://www.gimp.org/news/2019/06/12/gimp-2-10-12-released/
Happy GIMPing, --Mitch
Download
GIMP 2.10.12 is available from:
https://download.gimp.org/pub/gimp/v2.10/
and from the mirrors listed at:
https://www.gimp.org/downloads/devel/#mirrors
The sha256 and sha512 checksums of the tarball are:
7d80b58e0784120d57d327294f6a1fda281ff51a61935c2cd764da281acaac71 gimp- 2.10.12.tar.bz2
dd4af3f0fa6fca815d254b7f42aeff15412c38294f1f5bd491563e2b597fcb868e6adff 9001b196a68e01cf49bde61cbb153b662b8da1aa1b4b1f7285879659f gimp- 2.10.12.tar.bz2
Overview of Changes from GIMP 2.10.10 to GIMP 2.10.12 =====================================================
Core:
- Add an "Incremental" option to the Dodge/Burn tool, which, similarly to the Paintbrush, Pencil, and Eraser tools, applies the effect incrementally as the pointer moves. - Curves now have a concept of smooth vs corner points: smooth points produce a smooth curve, while corner points produce a sharp curve (previously, all points were smooth). - Search the user font directory path on Windows (since Windows 10, non-admin users have the ability to install fonts). This is only a temporary hack until fontconfig adds proper upstream support: https://gitlab.freedesktop.org/fontconfig/fontconfig/issues/144 - In gimp_brush_core_get_paint_buffer(), when allocating a new paint buffer, clear the old buffer *before* allocating the new one, to reduce the amount of simultaneously allocated memory. - In GimpPaintbrush, avoid refilling the paint buffer at each dab if the paint color/pixmap hasn't changed, hence allowing faster painting in some specific cases. - Add hygon cpu detection and enable MMX/SSE support. - Add a GimpSymmetry::get_transform() virtual function and a corresponding gimp_symmetry_get_transform() function which return the brush transform corresponding to a given symmetry stroke in terms of the rotation angle and reflection flag (in contrast to gimp_symmetry_get_operation() which returns the same transforation in terms of a GeglNode). This allows us to simplify, fix (artifact bugs, etc.), and improve the painting-code performance for several symmetry painting cases.
- New gimp-brush-pipe-spacing parasite set by core code to preserve GIH brush's spacing across reloads. - Add a new Offset filter tool, as a front-end to gimp:offset. The tool replaces, and provides the same interface as the drawable- offset dialog while also providing live preview and on-canvas interaction.
Plug-ins:
- Exported profile and data format strategy updated in several file plug-ins.
* When not saving a profile, we always export as sRGB data, as most viewers would not display the image properly otherwise. * When saving a profile:
* If a profile was manually assigned, we always export to the assigned format, hence pixel data is converted accordingly, whatever the work format.
* If no profile was assigned: * If the export format support high-bit depth, we export the work format as-is. * If the export format is 8-bit max, we convert the work format to sRGB, except if the work format is 8-bit linear.
The following plug-ins were updated: JPEG, PNG, TIFF and WebP.
- TIFF plug-in now supports layer export. - Add accelerator on "Save color _profile" item in JPEG export so that all items in the dialog have keyboard accelerators. - Add a "Save color profile" checkbox in WebP export and remove the "Advanced Options" expander (all metadata and profile writing options are now directly visible). - Process cases of non-conformant TIFF file with extra channels while ExtraSamples is not set by assuming the first extra channel is a non-premultiplied alpha channel and outputting a warning. In the future, this should be updated further by a dialog asking what to do with the non-defined dialog (consider as premultiplied or non-premultiplied alpha channel, or just save as extra channels).
Tools:
- Add input/output spin-buttons to the Curves tool, which allow setting the selected point's coordinates numerically. When the image precision is greater than 8-bpc, use a 0.00-100.00 range for the point-coordinate spin-buttons instead of a 0-255 range. - In the Curves tool, allow changing the curve's point types (cf. new curve corner points in Core section). Corner points are displayed with a diamond shape instead of a circle. - Free Select tool now creates a selection as soon as the polygon is closed. This selection is updated when the polygon, or the relevant tool-options, change, similarly to GimpRectangleSelectTool. - Derive GimpEraser from GimpPaintbrush, instead of directly from GimpBrushCore.
This allows GimpEraser to reuse the paint-buffer content across dabs, improving performance.
- Allow moving an intersecting pair of guides with the Move tool.
User interface:
- In GimpCurveView, when dragging an existing curve point, don't immediately move the point to the cursor position upon button press, but rather move it relative to its current position as the cursor moves. This allows selecting a point without moving it, and adjusting its position more easily. - when the cursor hovers above a point in GimpCurveView, or when dragging a point, have the coordinate indicator show the point's position, rather than the cursor's. - In GimpCurveView, when holding down Ctrl while adding/dragging a point, snap the y-coordinate to the original curve (at the start of the drag). This is particularly useful for adding points along the curve.
- In GimpDashboard, don't show legend for groups with no meter. - Add a tile-alloc-total variable to the dashboard's memory and misc groups, showing the total amount of memory used by the tile allocator.
- Add a "Save Keyboard Shortcuts Now" button to the Configure Keyboard Shortcuts dialog.
Installers:
- Windows: enable InnoSetup "unofficial" translations. Otherwise we had a bunch of wasted work from our translators of several languages whose translations were never used in the installer.
Translations:
- 12 translations were updated: Catalan, Chinese, French, German, Hungarian, Indonesian, Italian, Polish, Russian, Spanish, Swedish and Turkish.
Contributors: =============
Alexandre Prokoudine, Ell, Jehan, Kalev Lember, Massimo Valentini, Michael Natterer, Sabri Ünal, Tobias Ellinghaus, fanjinke, luz.paz, Øyvind Kolås.
Translators:
Alexandre Prokoudine, Anders Jonsson, Aron Xu, Balázs Úr, Carles Ferrando Garcia, Daniel Mustieles, Ell, Emin Tufan Çetin, Jordi Mas, Julien Hardelin, Kukuh Syafaat, Marco Ciampa, Mingye Wang, Piotr Drąg, Rodrigo Lledó, Sabri Ünal, Tim Sabsch, lumingzh.
2019-06-16 20:32:08 UTC (almost 6 years ago)
Dear all,
AppImage packages for the 2.10.12 are also available from here: https://github.com/aferrero2707/gimp-appimage/releases/tag/continuous
They should work on most of the common Linux distributions.
Two versions of the AppImage are provided, one with only the GIMP application , and a second one also including various popular plug-ins.
Best regards, Andrea
Download
Core:
Plug-ins:
Tools:
User interface:
Installers:
Translations:
Translators:
