to authors: images heads up
to authors: images heads up Marco Ciampa via gimp-docs-list 23 Mar 19:41
  to authors: images heads up Pat David via gimp-docs-list 24 Mar 15:39
2019-03-23 19:41:27 UTC (about 6 years ago)
Sometimes it is worth do some diagnostics, call it "spring cleaning" ;-) Many thanks to who created those wonderful (auto)make files:
make check-images-C *** Checking image references ...
parsing XML files ...
found 1799 references in 736 files
searching images in 'images/C' ... found 1810 image files
12 broken image references: BROKEN: images/dialogs/dialogs-icon-new-group.png IN src/dialogs/layer-dialog.xml BROKEN: images/dialogs/layer-group-visibility.png IN src/concepts/layer-groups.xml BROKEN: images/filters/examples/distort/ripple-ex-periode.png IN src/filters/distort/ripple.xml BROKEN: images/filters/examples/enhance/noise-reduction-ex1.gif IN src/filters/enhance/noise-reduction.xml BROKEN: images/filters/examples/enhance/noise-reduction-ex2.gif IN src/filters/enhance/noise-reduction.xml BROKEN: images/filters/examples/map/recursive_transform-first=2.png IN src/filters/map/recursive-transform.xml BROKEN: images/toolbox/handle-transform-ex-move.gif IN src/toolbox/transform/handle-transform.xml BROKEN: images/toolbox/handle-transform-ex-perspective.gif IN src/toolbox/transform/handle-transform.xml BROKEN: images/toolbox/handle-transform-ex-rotate.gif IN src/toolbox/transform/handle-transform.xml BROKEN: images/toolbox/handle-transform-ex-shear.gif IN src/toolbox/transform/handle-transform.xml BROKEN: images/toolbox/warp-ex-abyss.gif IN src/toolbox/transform/warp-transform.xml BROKEN: images/toolbox/warp-ex-swirl.gif IN src/toolbox/transform/warp-transform.xml 23 orphaned image files:
ORPHANED: images/C/filters/artistic/applycanvas.png ORPHANED: images/C/filters/artistic/cubism.png ORPHANED: images/C/filters/artistic/photocopy.png ORPHANED: images/C/filters/decor/fog.png ORPHANED: images/C/filters/distort/blinds.png ORPHANED: images/C/filters/distort/erase_rows.png ORPHANED: images/C/filters/edge-detect/image_gradient-dialog.png ORPHANED: images/C/filters/edge-detect/laplace-dialog.jpg ORPHANED: images/C/filters/examples/artistic/slic-ex-orig.jpg ORPHANED: images/C/filters/examples/distort-taj-blinds.jpg ORPHANED: images/C/filters/examples/distort/ripple-ex-period.png ORPHANED: images/C/filters/examples/example-map-warp1.png ORPHANED: images/C/filters/examples/example-map-warp2.png ORPHANED: images/C/filters/examples/example-map-warp3.png ORPHANED: images/C/filters/examples/example-map-warp4.png ORPHANED: images/C/filters/examples/example-map-warp5.png ORPHANED: images/C/filters/examples/example-map-warp6.png ORPHANED: images/C/filters/examples/example-map-warp7.png ORPHANED: images/C/filters/examples/example-map-warp8.png ORPHANED: images/C/filters/examples/generic/dist_map-high-2.png ORPHANED: images/C/filters/examples/map-taj-smalltile.jpg ORPHANED: images/C/filters/examples/taj_rows.jpg ORPHANED: images/C/filters/light-and-shadow/glasstile.png
someone please see to this...
TIA
Best regards,
Marco Ciampa
I know a joke about UDP, but you might not get it.
 GNU/Linux User #78271
 FSFE fellow #364
2019-03-24 15:39:46 UTC (about 6 years ago)
I can try to get a build environment setup and see if I can help. It may be a little bit, though.
On Sat, Mar 23, 2019 at 2:41 PM Marco Ciampa via gimp-docs-list < gimp-docs-list@gnome.org> wrote:
TIA
Best regards,
Marco Ciampa
GNU/Linux User #78271 FSFE fellow #364
_______________________________________________ gimp-docs-list mailing list
https://patdavid.net
GPG: 66D1 7CA6 8088 4874 946D  18BD 67C7 6219 89E9 57AC
