No access to gitlab
| No access to gitlab | Kolbjørn Stuestøl | 31 Aug 20:04 |
| No access to gitlab | Pat David via gimp-docs-list | 31 Aug 22:34 |
| No access to gitlab | Kolbjørn Stuestøl | 01 Sep 19:44 |
No access to gitlab
After gimp and gimp-help moved to gitlab ( in May 2018?) I am excluded
from the site.
In my local folder "gimp" in my main computer I created a new folder
named "gimp-help".
Typing "git clone git@gitlab.gnome.org/GNOME/gimp-help.git" or
git@gitlab.gnome.org/GNOME/gimp.git" results in the following message:
    Cloning into 'gimp-help.git.'...
    The authenticity of host 'gitlab.gnome.org (209.132.180.181)' can't
    be established.
    ECDSA key fingerprint is
    SHA256:go/hN+LitpIzHaSGRlpg7AbZn3nuziiKA7OXbMURiW4.
    Are you sure you want to continue connecting (yes/no)?
If I answer yes, these message shows up:
    Failed to add the host to the list of known hosts
    (/home/kolbj/.ssh/known_hosts).
    Connection closed by 209.132.180.181 port 22
    fatal: Could not read from remote repository.
    Please make sure you have the correct access rights
    and the repository exists.
Tried the same commands on another computer (the one I have used for some years translating). Result:
    git clone git@gitlab.gnome.org:GNOME/gimp-help
    Cloning into 'gimp-help'
    Permission denied
    Fatal: Could not read from remote repository.
Please make sure you have the correct access rights And the repository exists.
What do I have to do to get access? Where do I find documentation on how to change to gitlab? Is there another forum to ask?
I am running Cygwin on Windows 7 and 10 but I do not think that's the problem. It has worked fine for many years. Kolbjørn
Denne e-posten har blitt sjekket for virus av antivirusprogramvare fra Avast
https://www.avast.com/antivirus
No access to gitlab
I’d start here:
You may just need to check your access (LDAP?). On Fri, Aug 31, 2018 at 3:04 PM Kolbjørn Stuestøl wrote:
After gimp and gimp-help moved to gitlab ( in May 2018?) I am excluded from the site.
In my local folder "gimp" in my main computer I created a new folder named "gimp-help".
Typing "git clone git@gitlab.gnome.org/GNOME/gimp-help.git" or git@gitlab.gnome.org/GNOME/gimp.git
message:Cloning into 'gimp-help.git.'... The authenticity of host 'gitlab.gnome.org (209.132.180.181)' can't be established.
SHA256:go/hN+LitpIzHaSGRlpg7AbZn3nuziiKA7OXbMURiW4. Are you sure you want to continue connecting (yes/no)?If I answer yes, these message shows up:
Failed to add the host to the list of known hosts (/home/kolbj/.ssh/known_hosts).
Connection closed by 209.132.180.181 port 22 fatal: Could not read from remote repository. Please make sure you have the correct access rights and the repository exists.Tried the same commands on another computer (the one I have used for some years translating). Result:
git clone git@gitlab.gnome.org:GNOME/gimp-help Cloning into 'gimp-help'
Permission denied
Fatal: Could not read from remote repository.Please make sure you have the correct access rights And the repository exists.
Virusfri.
www.avast.com_______________________________________________ gimp-docs-list mailing list
gimp-docs-list@gnome.org
https://patdavid.net GPG: 66D1 7CA6 8088 4874 946D 18BD 67C7 6219 89E9 57AC
No access to gitlab
Den 01.09.2018 00:34, skreiv Pat David:
I’d start here:
Thank you, I'll try this.
Kolbjørn
You may just need to check your access (LDAP?). On Fri, Aug 31, 2018 at 3:04 PM Kolbjørn Stuestøl > wrote:
Typing "git clone git@gitlab.gnome.org/GNOME/gimp-help.git " or
git@gitlab.gnome.org/GNOME/gimp.git " results in the
following message:Cloning into 'gimp-help.git.'... The authenticity of host 'gitlab.gnome.org (209.132.180.181)' can't be established. ECDSA key fingerprint is
Failed to add the host to the list of known hosts (/home/kolbj/.ssh/known_hosts). Connection closed by 209.132.180.181 port 22 fatal: Could not read from remote repository. Please make sure you have the correct access rights and the repository exists.
Permission denied
Virusfri. www.avast.com
https://mail.gnome.org/mailman/listinfo/gimp-docs-list-- https://patdavid.net
Kolbjørn Stuestøl, Stuestølveien 212, 4580 Lyngdal Telefon: (47) 38 34 78 62, (47) 917 81 125 Stuestøl heimesider: http://www.stuestoel.no Andre sider eg administrerer: Lyngdal hagelag: http://lyngdal.hagelag.no (Passive sider: http://www.stuestoel.no/hagelag/hagelag.php) Mandal og Lister pyntegrøntlag: http://www.mlpynt.no Member of the GIMP Documentation Team Language coordinator LibreOffice (www.libreoffice.org/) --- Denne e-posten har blitt sjekket for virus av antivirusprogramvare fra Avast https://www.avast.com/antivirus
