Trouble building Gimp from GIT repo (20180530)
Trouble building Gimp from GIT repo (20180530) Steven P. Ulrick 31 May 02:41
  Trouble building Gimp from GIT repo (20180530) Kevin Cozens 31 May 06:08
   Trouble building Gimp from GIT repo (20180530) (SOLVED) Steven P. Ulrick 31 May 10:56
Steven P. Ulrick
2018-05-31 02:41:48 UTC (almost 7 years ago)
Hello, Everyone
I am attempting to build Gimp from GIT and I get the following error:
"Error: GIMP configuration failed.
  - Error: missing dependency glib-networking       *** Test for glib-networking failed. This is required.   - Error: missing dependency pangocairo >= 1.42.0 and pangoft2       *** We require Pango with the optional support for Cairo compiled in."
I am only asking about the glib-networking error right now.
INSTALL.in says the following:
19. Summary of required packages and what version you need:
glib-networking
So, INSTALL.in does not appear to specify which version of glib-networking that I need.
I do have the following installed:
glib-networking-2.54.1-1.fc27.x86_64 glib-networking-tests-2.54.1-1.fc27.x86_64
Any ideas why Gimp doesn't like the version of glib-networking that I have installed.
I believe that did my due dilegence better this time than the last time I had an issue like this.  If I missed something obvious again, I do apologize.
Steven P. Ulrick
Kevin Cozens
2018-05-31 06:08:40 UTC (almost 7 years ago)
[snip]
I think you are missing an environment variable. Add the following: export GIO_EXTRA_MODULES=/usr/lib/x86_64-linux-gnu/gio/modules/
IIRC, if you are on Windows use "set" instead of "export".
Cheers!
Kevin.
http://www.ve3syb.ca/               | "Nerds make the shiny things that
https://www.patreon.com/KevinCozens | distract the mouth-breathers, and
                                     | that's why we're powerful"
Owner of Elecraft K2 #2172          |
#include      |             --Chris Hardwick
Steven P. Ulrick
2018-05-31 10:56:01 UTC (almost 7 years ago)
[snip]
Hello, Kevin
With the small difference that it is "/usr/lib64/gio/modules/" on Fedora 27, your information fixed my issue.  Well, after I satisfied the Pango dependency, that is.
Thank you, Steven P. Ulrick
