gimptool with 2.99
gimptool with 2.99 Jean-Luc Coulon (f5ibh) 25 May 18:53
  gimptool with 2.99 Alexandre Prokoudine 25 May 20:52
   gimptool with 2.99 Jean-Luc Coulon (f5ibh) 26 May 05:56
2018-05-25 18:53:30 UTC (almost 7 years ago)
gimptool with 2.99
When I issue "gimptool-2.99 --libs" (from git master), I get:
Package gimpui-2.0 was not found in the pkg-config search path. Perhaps you should add the directory containing `gimpui-2.0.pc' to the PKG_CONFIG_PATH environment variable No package 'gimpui-2.0' found
No output from 'pkg-config --libs gimpui-2.0'
Of course, I dont have gimpui-2.0 but 3.0.
Did I do something wrong?
Regards
Jean-Luc
2018-05-25 20:52:17 UTC (almost 7 years ago)
gimptool with 2.99
пт, 25 мая 2018 г., 21:53 Jean-Luc Coulon (f5ibh):
Apart from trying to build and use something currently not intended to be used at all? :)
Alex
2018-05-26 05:56:44 UTC (almost 7 years ago)
gimptool with 2.99
2018-05-25 22:52 GMT+02:00 Alexandre Prokoudine < alexandre.prokoudine@gmail.com>:
Really "at *all*"? :)
J-L
(anyway, thanks)
List address: gimp-developer-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp- developer-list
List archives: https://mail.gnome.org/archives/gimp-developer-list
