libmypaint version for building GIMP-2.10.0
libmypaint version for building GIMP-2.10.0 Carmelo DrRaw 27 Apr 17:18
  libmypaint version for building GIMP-2.10.0 Jehan Pagès 27 Apr 22:38
  libmypaint version for building GIMP-2.10.0 Helmut Jarausch 28 Apr 10:53
Carmelo DrRaw
2018-04-27 17:18:53 UTC (over 6 years ago)
Dear all,
I am currently stuck with what seems to be a version dependency conflict between GIMP and libmypaint-1.3.0.
GIMP requires GEGL >= v0.4.0, however libmypaint still requires GEGL v0.3.x:
checking for GEGL... no configure: error: Package requirements (gegl-0.3 >= 0.3) were not met:
No package 'gegl-0.3' found
This happens because GEGL v0.4.x only provides gegl-0.4.pc
I am using the latest official release of libmypaint: https://github.com/mypaint/libmypaint/releases/download/v1.3.0/libmypaint-1.3.0.tar.xz
Should I use a specific commit instead?
Thanks a lot!
Jehan Pagès
2018-04-27 22:38:23 UTC (over 6 years ago)
Hi!
On Fri, Apr 27, 2018 at 7:18 PM, Carmelo DrRaw wrote:
Dear all,
Which is normal, since it is GEGL 0.4, not 0.3. ;-)
And yes, you are right. The GEGL dependency in libmypaint is GEGL v0.3, and I am not sure that will change soon, since libmypaint developers are mostly working on libmypaint v2 now. You can still ask them if they would make a libmypaint v1 with updated GEGL dep.
BUT for the time being, it is not much a problem because (1) GEGL v0.3 and v0.4 can be installed next to each other (hence the different namespace) and (2) you don't have to build libmypaint with GEGL. libmypaint-gegl is not used by GIMP in any way to this day. So just build libmypaint with --disable-gegl and don't care about installing GEGL v0.3.
I am using the latest official release of libmypaint: https://github.com/mypaint/libmypaint/releases/download/ v1.3.0/libmypaint-1.3.0.tar.xz
libmypaint version is right. This is the GEGL version whose version you did not correctly installed.
Jehan
Thanks a lot! _______________________________________________ gimp-developer-list mailing list
List address: gimp-developer-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp- developer-list
List archives: https://mail.gnome.org/archives/gimp-developer-list
ZeMarmot open animation film
http://film.zemarmot.net
Liberapay: https://liberapay.com/ZeMarmot/
Helmut Jarausch
2018-04-28 10:53:10 UTC (over 6 years ago)
On 04/27/2018 07:18:53 PM, Carmelo DrRaw wrote:
Dear all,
I have applied the following "patches" With these libmypaint compiles fine.
Helmut
sed -i -e'/gegl_required_version/ s/0.3/0.4/' configure.ac sed -i -e's/gegl-0.3/gegl-0.4/g' gegl/Makefile.in sed -i -e's/gegl-0.3/gegl-0.4/g' gegl/Makefile.am sed -i -e's/gegl-0.3/gegl-0.4/g' gegl/libmypaint-gegl.pc.in sed -i -e's/Gegl-0.3/Gegl-0.4/g' gegl/Makefile.am sed -i -e's/Gegl-0.3/Gegl-0.4/g' gegl/Makefile.in sed -i -e's/gegl-0.3 >= 0.3/gegl-0.4 >= 0.4/g' configure
