Blend tool midpoints
Blend tool midpoints Julien Hardelin 07 Apr 12:30
  Blend tool midpoints Ell via gimp-docs-list 08 Apr 11:24
   Blend tool midpoints Julien Hardelin 09 Apr 05:54
Julien Hardelin
2018-04-07 12:30:03 UTC (about 7 years ago)
In Blend tool, what are midpoints?
Normally, the midpoint of an interval can be found by finding the half-way point of each of the x and y values of the 2 points that define the interval.
In Blend tool, midpoint often is not at center of gradient segment, between two stops (and there is an option to place it at center).
How to explain what midpoint is, here?
Julien
2018-04-08 11:24:01 UTC (about 7 years ago)
Midpoints are the points along the gradient where the two endpoint *colors* of a segment are equally blended. By default, midpoints are placed at the geometric center of the segment, but they can be moved to any other point along the segment.
Note that a lot of the relevant concepts might already be covered in the documentation for the "old" gradient editor (gimp-gradient-editor-dialog section), so it's worth taking a look at.
-- Ell
Julien Hardelin
2018-04-09 05:54:37 UTC (about 7 years ago)
Thank you , Ell, for your explanation.
Julien
