Enhancement Request for GIMP: Clone layers
Enhancement Request for GIMP: Clone layers Miguel Lopez 06 Feb 03:13
  Enhancement Request for GIMP: Clone layers Øyvind Kolås 07 Feb 08:52
Miguel Lopez
2018-02-06 03:13:28 UTC (about 7 years ago)
Hi GIMP developers,
Complying with the wishes of developers - " An enhancement request should never be filed without prior discussion on the gimp-developer mailing list."
That being said, I wonder if GIMP would benefit from clone layers found in Krita. Clone layers enables automated editing by simply copy and pasting. Like literally, you don't need to copy and paste or change layers manually, and you can do some quick operations without the need for scripting for some tasks. Like say, if you can use group as a clone layer, you can literally use a clone layer of a group into different group with different layers overlay, and automate your editing.
In the long run, when GIMP 3.x comes, this may introduce issue such as massive slowdowns as if you were to clone a group with filter layers on it, this would severely slow down editing at the benefit of enabling automated editing which save time in the long run.Also, there does seem to be a issue of loop to be considered.
To explain further:
1. Let's say a GIMP document has this setup.
- Group Layer A
--> Paint Layer
2. Okay, now let's say we want to make a clone layer of "Group Layer A". It becomes:
-Instanced Layer of Group Layer A
-Group Layer A
--> Paint Layer
3. Now, let's move on to moving the instanced layer into Group Layer A
-Group Layer A
--> Instanced Layer of Group Layer A
--> Paint Layer
You see the problem here?
Thank you for reading,
Miguel Lopez
Øyvind Kolås
2018-02-07 08:52:42 UTC (about 7 years ago)
On Tue, Feb 6, 2018 at 4:13 AM, Miguel Lopez wrote:
Hi GIMP developers,
Clones in the layer stack is the direction I have been pushing GIMP towards since 2007/2008, but GIMP takes a lot of time to catch up. Any acyclic processing graph consisting of only nodes with 1 output pad and 1-2 input pads can be expressed as a node-tree with clones. And conversion can be automatic, this is also how the GEGL XML representation of arbitrary graphs is expressed.
/Øyvind K - https://pippin.gimp.org/
