plugin development
plugin development p144a@kabsi.at 31 Dec 14:17
  plugin development Michael Natterer 06 Jan 11:33
p144a@kabsi.at
2017-12-31 14:17:02 UTC (over 7 years ago)
plugin development
Hi!
I am developing a Gimp plugin in C and have a question, but if this is not the right place to ask, please tell me so and accept my apology.
The plugin requires the user to select a color, but i can't figure out the correct way to do it. In lack of better knowledge i am using a field of type GimpRGB for the struct that holds the plugin options and the GimpParamDef in the query() function has an entry that looks like this:   {
    GIMP_PDB_COLOR,
    "inside color",
    "Inside color"
In the run() function i set the color field of the option like this:   options.inside_color = param[ PARAM_INSIDE_COLOR ].data.d_color;
Again in lack of better knowledge, my function that builds the dialog for chosing options uses a GtkColorButton for the user to pick a color and i connect the signal "color_set" in the following way to a callback which is defined like this:
  static void color_set( GtkColorButton *button, gpointer data ) {     gtk_color_button_get_color( button, data );   }
and when building the dialog i connect it like this: g_signal_connect( color_button, "color_set", G_CALLBACK( color_set ), &options.inside_color );
The gimptool compiles my plugin and it is registered and runs as expected in the Gimp.
However, when building the dialog, i try to set the color that was stored in he options from a previous run like this:
  gtk_color_button_set_color( ( GtkColorButton * ) color_button, &options.inside_color );
the gimptool gives me a warning:   expected ‘const struct GdkColor *’ but argument is of type ‘struct GimpRGB *’
When googling for help i read that GdkColor is deprecated?? and i want to ask you for the correct and preferred way of doing this.
Sorry, if what i want is not clear, i am not a native english speaker and i will happily answer if you need more information.
Regards and Thanks, Paul
Michael Natterer
2018-01-06 11:33:51 UTC (over 7 years ago)
plugin development
On Sun, 2017-12-31 at 15:17 +0100, p144a@kabsi.at wrote:
Hi!
GIMP_PDB_COLOR,
"inside color",
"Inside color"
in the Gimp.
You would simply use a GimpColorButton and gimp_color_button_new()
Regards, Mitch
