compiler advantages
compiler advantages Carol Spears 16 Nov 17:20
Carol Spears
2017-11-16 17:20:16 UTC (over 7 years ago)
compiler advantages
Sorry, more questions....
I had to use gcc-5 to compile a kernel, then I didn't re-symlink to gcc-6 and have been building gimp, gegl and babl with it since then. With the exception of openexr, everything seems to be building fine.
Is there an advantage to using gcc-6 instead of gcc-5?
And, a related question. I don't know why openexr started to give me problems. When I look into the problems, I am going to start with libtiff (like, maybe it *needed* that pixar-log stuff or libtiff++). What do I loose not having openexr available to gegl and gimp?
Thanks, carol
