Warp transform Abyss policy
10 of 10 messages available
Warp transform Abyss policy Julien Hardelin 13 Jun 16:39
  Warp transform Abyss policy Ell via gimp-developer-list 13 Jun 20:06
   Warp transform Abyss policy Julien Hardelin 14 Jun 05:28
   Warp transform Abyss policy Marco Ciampa via gimp-developer-list 14 Jun 05:44
    Warp transform Abyss policy Julien Hardelin 14 Jun 05:52
     Warp transform Abyss policy Marco Ciampa via gimp-developer-list 14 Jun 06:15
    Warp transform Abyss policy Ell via gimp-developer-list 14 Jun 11:01
     Warp transform Abyss policy Marco Ciampa via gimp-developer-list 14 Jun 19:40
      Warp transform Abyss policy Ell via gimp-developer-list 15 Jun 14:01
       Warp transform Abyss policy Marco Ciampa via gimp-developer-list 15 Jun 14:20
Julien Hardelin
2017-06-13 16:39:39 UTC (almost 8 years ago)
Hello developers,
I am writing gimp-help-2 doc for warp transform tool and I have difficulty with "Abyss policy". I read the wiki/glossary for these items but did not understand what they do.
How to explain these features to users?
Julien Hardelin
2017-06-13 20:06:09 UTC (almost 8 years ago)
On Tue, 13 Jun 2017 18:39:39 +0200 Julien Hardelin wrote:
Hello developers,
Granted, the abyss policy option is a bit on the technical side.
The warp tool moves pixels from one point to another. Some pixels may come from outside the layer boundary. These pixels don't actually exist anywhere, and therefore don't have any associated color; yet, we must assign *some* color to them. The abyss policy specifies how to determine their color:
- None: Assume that all pixels outside the layer boundary are transparent.
- Clamp: Assume that each edge of the layer stretches out indefinitely, so, for example, a pixel to the left of the layer boundary has the same color as the leftmost pixel of the layer with the same y coordinate. An alternative way to think of it is that each pixel outside the layer boundary has the same color as the closest pixel inside the layer boundary.
- Loop: Assume that the layer repeats itself in all directions, so that, for example, falling off the right edge of the layer takes you back to the left edge.
And here's a quick comparison of the three modes: http://i.imgur.com/R5RKkLF.gif
You'll find an abyss policy option in some of the filters as well, with a similar function. In filters, there are additional "black" and "white" modes, which are similar to "none", but use black and white for out-of-bounds pixels, instead of transparency.
-- Ell
Julien Hardelin
2017-06-14 05:28:29 UTC (almost 8 years ago)
Thank you, Ell, for these clear explanations.
Julien
2017-06-14 05:44:28 UTC (almost 8 years ago)
Hello developers,
Veeery interesting indeed Ell! And also very clear! Do you know exactly which tools share this same option?
Your example seems to come from the whirl-pinch distortion filter but I do not see any abyss option in the filter option dialog... even in any other filter option dialog... am I looking in the wrong place?
PS: also I see that in the warp tool the Abyss options remains translated in my system language (Italian) even if I set the gimp language to English... here and there there are some other translated particulars like 4 controls in the render->patterns->checkboard filter, tooltips, keyboard accelerators...small bug?
TIA
Marco Ciampa
I know a joke about UDP, but you might not get it.
 GNU/Linux User #78271
 FSFE fellow #364
Julien Hardelin
2017-06-14 05:52:22 UTC (almost 8 years ago)
I have the same problem in several tools: with GIMP in the en-US language, some tool options are in French.
Julien
TIA
2017-06-14 06:15:42 UTC (almost 8 years ago)
The only way to do it right (and changes other things like icon appearances...) is doing a:
export LANGUAGE=en_US; gimp
Marco Ciampa
GNU/Linux User #78271 FSFE fellow #364
2017-06-14 11:01:10 UTC (almost 8 years ago)
On Wed, 14 Jun 2017 07:44:28 +0200 Marco Ciampa via gimp-developer-list wrote:
Warp is the only tool that has an abyss policy option, IIRC. As for filters, convolution matrix, displace, edge, fractal trace, and Gaussian blur all have this option, although some of them call it "border" or "border behavior" instead. Bump map, ripple, and waves also have a toggle that switches between two of the abyss policy modes, although they call it "clamp", or "tiled/tileable".
The example uses the warp tool, of course :) It is in swirl mode, though, as you guessed. The whirl/pinch filter indeed lacks this option.
The text for the abyss policy items comes from GEGL. It seems that switching the language in the preferences only affects GIMP text, and not GEGL. We should probably fix that, since it affects all the GEGL filters.
Ell
2017-06-14 19:40:39 UTC (almost 8 years ago)
Ok probably a more coherent choice for a label for all these tools would be a good idea...
Very good catch!
Now you said it I see that all the untranslated operations are GEGL... :-)
Marco Ciampa
 FSFE fellow #364
2017-06-15 14:01:49 UTC (almost 8 years ago)
On Wed, 14 Jun 2017 21:40:39 +0200 Marco Ciampa via gimp-developer-list wrote:
There are other similar inconsistencies across the different filters. It would be nice if we made sure they're better aligned before 2.10.
Very good catch!
Aaaand... fixed in master. Commit d37fb8aa5c915b57d07da2f2e48fac36e75e7a64.
-- Ell
2017-06-15 14:20:27 UTC (almost 8 years ago)
yes, definitely!
Said and done like a wizard, great! :-)
Marco Ciampa
 FSFE fellow #364
