high bit depth tiff issues
high bit depth tiff issues Casey Connor 28 Apr 06:07
  high bit depth tiff issues Michael Natterer 28 Apr 07:55
   high bit depth tiff issues Casey Connor 28 Apr 16:49
Casey Connor
2017-04-28 06:07:27 UTC (almost 8 years ago)
...and a final follow-up, just so people don't need to spend any time on this: changing the range with g'mic makes the files work properly in GIMP:
gmic 16bit_input.tif -/ 65535 -o 32bit_float_output.tif
(that scales the output to the [0,1] range.)
So that seems like the logical way to handle this, unless gimp wanted to handle large ranges automatically or something. (Apparently the CCE edition is already doing that to some extent.)
-c
Michael Natterer
2017-04-28 07:55:06 UTC (almost 8 years ago)
Hi Casey,
thanks for investigating this issue. GIMP should load all these files just fine. I think support for 16/32 bit float TIFF was added without checking what range the values would have.
GIMP completely ignores TIFFTAG_{MAX,MIN}SAMPLEVALUE, and according to the spec they should default to
2**(BitsPerSample) - 1
which is just the scaling factor of 65535 you encountered.
However not for 32 bit files, but judging from your command line above I assume you meant 16 bit, or both gmic and gimp are broken, who knows :)
Can you please file a bug and attach the sample files?
The fix should be trivial, but I need some files to test.
Regards, Mitch
Casey Connor
2017-04-28 16:49:44 UTC (almost 8 years ago)
Yeah, my g'mic example had a semantic mistake, sorry: it should have read something like:
gmic 32bit_float_input_with_range_to_65535.tif -/ 65535 -o 32bit_float_output.tif
...meaning, GIMP opens the 16bit integer stuff fine, it's the float format with an unexpected range that gives it trouble. There is a normalize operator ("-n 0,1") for g'mic, but as the g'mic developer points out, that could mess with the dynamic range, so using the divisor (-/) you can scale it appropriately. (E.g. -/ 255 if the original ranged over an 8bit scale.)
Will do! Thanks!
-c
