gimp-edit-copy
gimp-edit-copy Peter Suetterlin 17 Apr 10:05
  gimp-edit-copy Michael Natterer 17 Apr 12:46
   gimp-edit-copy Peter Suetterlin 17 Apr 15:09
  gimp-edit-copy Michael Natterer 17 Apr 12:48
  gimp-edit-copy Ofnuts 17 Apr 13:10
   gimp-edit-copy Peter Suetterlin 17 Apr 15:14
Peter Suetterlin
2017-04-17 10:05:51 UTC (about 8 years ago)
gimp-edit-copy
I recently switched to the 2.9 series of gimp(*). Some of the script-fus I regularly use do need babysitting, in particular the 'maximize local contrast' script by Roy Johnson. I fixed the deprecated function calls, but it always failed in the final step where an edit buffer captured via gimp-edit-copy should be pasted into a layer mask.
After some debugging on the script-fu console it turned out the reason for the failure was that the edit buffer was empty.
I could fix the problem by selecting the full area before the call to gimp-edit-copy. But acording to the docs it should do this by itself if nothing is selected.
Has this changed lately, or is it a bug to report?
I'm running openSUSE Tumbleweed, with a package from home:/Herbster0815. It's called gimp-2.9.4-64.12, but reports itself as 2.9.5, so I don't know the exact version but assume it's from git?
Pit
(*) Really amazing! You're doing a really great job on this. I'll for sure stick with 2.9
Dr. Peter "Pit" Suetterlin                 http://www.astro.su.se/~pit
Institute for Solar Physics
Tel.: +34 922 405 590  (Spain)             P.Suetterlin@royac.iac.es
      +46 8 5537 8559  (Sweden)            Peter.Suetterlin@astro.su.se
Michael Natterer
2017-04-17 12:46:23 UTC (about 8 years ago)
gimp-edit-copy
Hi Peter,
If any script works fine in 2.8, but not in git master, please file a bug.
Mitch
failed in the final step where an edit buffer captured via gimp-edit- copy
  Pit
stick with 2.9
Michael Natterer
2017-04-17 12:48:39 UTC (about 8 years ago)
gimp-edit-copy
  Pit
stick with 2.9
Oh, and thanks a lot! :)
2017-04-17 13:10:29 UTC (about 8 years ago)
gimp-edit-copy
IMHO the real fix is to use other ways to move pixels. Applications should not use the clipboard for their own purposes, this interferes with the user's other apps.
Peter Suetterlin
2017-04-17 15:09:14 UTC (about 8 years ago)
gimp-edit-copy
Hi Mitch,
OK, here: https://bugzilla.gnome.org/show_bug.cgi?id=781408
Cheers,
Pit
Peter Suetterlin
2017-04-17 15:14:05 UTC (about 8 years ago)
gimp-edit-copy
Well, it isn't about getting the script to run on first place. It's rather that the docs say the function copies the whole drawable without a set selection, but it seems it doesn't (it does in 2.8).
That is independent of what you intend to do with that buffer...
Pit
