Point-and-click tool to create guides?
8 of 9 messages available
Point-and-click tool to create guides? wwp 09 May 19:47
  Point-and-click tool to create guides? Alexandre Prokoudine 09 May 19:54
   Point-and-click tool to create guides? C R 09 May 20:02
    Point-and-click tool to create guides? wwp 09 May 20:23
     1462826797524.387432493@boxbe 10 May 21:14
      Point-and-click tool to create guides? Joseph Bupe 09 May 21:30
     Point-and-click tool to create guides? C R 09 May 20:30
      Point-and-click tool to create guides? wwp 09 May 20:41
   Point-and-click tool to create guides? wwp 09 May 20:20
wwp
2016-05-09 19:47:17 UTC (almost 9 years ago)
Hello there,
I wonder if the idea of a point-and-click tool to create guides could be a good one?
The idea there is to directly create guides with a minimum number of clicks in order to speed up a production process. It is based upon my (long, subjective and perfectible) experience w/ the Gimp 2.x.
The way of doing it could be, for instance: in one click you pick the create-guide tool from the side dock, then you click on the image: it creates a horizontal or vertical guide at this click's x or y - horizontal or vertical axis could be determined using ctrl or shift modifier. Clicking in the margin (outside the layer boundary) could be even more intuitive, up/down margin to create vertical guides, left/right to create horizontal ones, still for instance. While moving the mouse pointer with this tool, a "live" guide shadow could be displayed, in order to provide a visual clue about the guide location that you validate when you click to create it.
Any thought?
wwp
2016-05-09 19:54:12 UTC (almost 9 years ago)
On Mon, May 9, 2016 at 10:47 PM, wwp wrote:
Hello there,
Any thought?
Just to make sure I get it right...
Instead of
1. Hovering your mouse pointer over the ruler. 2. Clicking, dragging, and releasing the mouse button to create a new guide.
...you want
1. Hover your mouse pointer over the toolbox above the 'point-and-click tool' and click it. 2. Go to the location where you want a guide and use a modifier to create either vertical or horizontal (or both) guides.
Unless I'm terribly mistaken, that's about the same amount of step in comparison to something that has been around for years :) You you get guide position preview too.
Hmmm? :)
Alex
C R
2016-05-09 20:02:21 UTC (almost 9 years ago)
This is also sub-function of the measure tool. To create a horizontal guide, place a marker on the spot, and ctrl-click it To create a vertical guide, place a marker on the spot and alt-click it
-C
On Mon, May 9, 2016 at 8:54 PM, Alexandre Prokoudine < alexandre.prokoudine@gmail.com> wrote:
Hello there,
Any thought?
Instead of
...you want
Hmmm? :)
Alex _______________________________________________ gimp-developer-list mailing list
https://mail.gnome.org/mailman/listinfo/gimp-developer-list List archives: https://mail.gnome.org/archives/gimp-developer-list
wwp
2016-05-09 20:20:35 UTC (almost 9 years ago)
Hello Alexandre,
Hello there,
Any thought?
Instead of
...you want
Hmmm? :)
Hah. Dragging from the rulers does exactly what I need, the feature already exists. Thanks!!
wwp
wwp
2016-05-09 20:23:02 UTC (almost 9 years ago)
Hello C,
Nice too, thanks for the tip! :-)
Hello there,
Any thought?
Instead of
...you want
Hmmm? :)
wwp
C R
2016-05-09 20:30:48 UTC (almost 9 years ago)
What would be nice is a manual entry box for moving the measure tool markers around (in the Tool Options for measure). This way you could type in the exact value(s) you want, and use ctrl-click and alt-click to make your markers how you like with better precision than the mouse pointer allows.
Just a thought.
-C
On Mon, May 9, 2016 at 9:23 PM, wwp wrote:
Hello C,
it
Hello there,
be
moving
Any thought?
Instead of
...you want
Hmmm? :)
wwp
wwp
2016-05-09 20:41:03 UTC (almost 9 years ago)
Right!
Even ore because clicking the spot line (layer boundary, one-pixel wide line) is a bit difficult - but maybe it's just me.
Hello C,
it
Hello there,
be
moving
Any thought?
Instead of
...you want
Hmmm? :)
wwp
wwp
Joseph Bupe
2016-05-09 21:30:47 UTC (almost 9 years ago)
I only wish the free select tool had a toggle option for drawing guides (horizontal, vertical diagonal) more like how the free select operates could be better.
On 9 May 2016 at 22:30, C R wrote:
[image: Boxbe] This message is eligible for Automatic Cleanup! (cajhne@gmail.com) Add cleanup rule
| More info
Just a thought.
-C
Hello C,
ctrl-click
it
Hello there,
could
be a good one?
of
my
the
be
moving
location
Any thought?
Instead of
...you want
Hmmm? :)
wwp
