Problems with JPG?!
8 of 8 messages available
Problems with JPG?! Stefan Rohde 31 Jan 15:29
  Problems with JPG?! Mukund Sivaraman 31 Jan 17:14
   Problems with JPG?! Mukund Sivaraman 31 Jan 17:49
  Problems with JPG?! Sven Claussner 31 Jan 17:29
  Problems with JPG?! Shlomi Fish 31 Jan 17:32
  Problems with JPG?! Michael Schumacher 31 Jan 20:31
   Problems with JPG?! Kevin Payne 31 Jan 22:22
    Problems with JPG?! Robert Krawitz 31 Jan 23:40
Stefan Rohde
2016-01-31 15:29:43 UTC (about 9 years ago)
Problems with JPG?!
Dear GIMP-Team,
I can not display images that I have prepared and saved with GIMP 2.8.14 (under Windows 10) in jpg-format on my TV or via a digital box (WD TV). On my PC its no problem!
The Thumbnailes can be seen but the images can not be read! I have also tried several setting for the jpg-saving.
Other images I prepared with former versions are working well!
Do you have an idea or information !?
Kind regards Stefan Rohde
Germany
Mukund Sivaraman
2016-01-31 17:14:17 UTC (about 9 years ago)
Problems with JPG?!
Hi Stefan
On Sun, Jan 31, 2016 at 04:29:43PM +0100, Stefan Rohde wrote:
Dear GIMP-Team,
Can you create a GIMP bug ticket on bugzilla.gimp.org and attach a sample JPEG image that is broken?
Mukund
Sven Claussner
2016-01-31 17:29:40 UTC (about 9 years ago)
Problems with JPG?!
Hi Stefan,
did you also try various settings of the subsampling (in the German dialog box: Zwischenschritte, although 'Farbunterabtastung' is the proper translation here)? If you report a bug, please make sure to use version 2.8.16 which is the latest.
Greetings
Shlomi Fish
2016-01-31 17:32:36 UTC (about 9 years ago)
Problems with JPG?!
Hi Mr. Rohde,
please reply to all recipients.
On Sun, 31 Jan 2016 16:29:43 +0100 Stefan Rohde wrote:
Dear GIMP-Team,
Can you send us a sample image ? It is possible that your television implements only a subset of the JPEG standard. To verify , can you let me know if the following JPEG file that I first converted to PNG using ImageMagick and then saved as JPEG From GIMP is fine:
* http://www.shlomifish.org/Files/files/images/chickpeas.xcf.bz2
* http://www.shlomifish.org/Files/files/images/chickpeas-from-xcf.png
* http://www.shlomifish.org/Files/files/images/chickpeas-from-xcf.jpg
The SHA-256 sums for them are:
cbb78ae42b96b2aa85ebce7ed6cc6e2378d13562b6076673df8edb57f6ad2f20 chickpeas-from-xcf.jpg
a4a5dd3512b0b89f476647e287a4f18359bc99af9f06776c6a933ae7c4e7fd8d chickpeas-from-xcf.png
1f9b974716bda9f8374be083c044623bf3277e7f7fd3f95b56633b98354ccc20 chickpeas.xcf.bz2
Can you give an example of a JPEG file that your television views properly?
Shlomi Fish
Germany
Shlomi Fish       http://www.shlomifish.org/
Humanity - Parody of Modern Life - http://shlom.in/humanity
When a FLOSS developer says they will work on something, he or she means
“maybe”.
Please reply to list if it's a mailing list post - http://shlom.in/reply .
Mukund Sivaraman
2016-01-31 17:49:32 UTC (about 9 years ago)
Problems with JPG?!
On Sun, Jan 31, 2016 at 10:44:17PM +0530, Mukund Sivaraman wrote:
Hi Stefan
Dear GIMP-Team,
Sorry that's https://bugzilla.gnome.org/
Mukund
2016-01-31 20:31:25 UTC (about 9 years ago)
Problems with JPG?!
Am 31.01.2016 um 16:29 schrieb Stefan Rohde:
It's most likely the Progressive option in the advanced part of the JPEG export dialog.
Kevin Payne
2016-01-31 22:22:55 UTC (about 9 years ago)
Problems with JPG?!
Yes it's almost certainly the bug that won't get fixed raising it's ugly head again: https://bugzilla.gnome.org/show_bug.cgi?id=723153
Kevin
From: gimp-developer-list  on behalf of Michael Schumacher
Sent: 31 January 2016 20:31
Subject: Re: [Gimp-developer] Problems with JPG?!
export dialog.
Robert Krawitz
2016-01-31 23:40:02 UTC (about 9 years ago)
Problems with JPG?!
Manufacturers simply aren't going to fix their firmware, particularly for older devices (read: are already on the market). And it's possible that a firmware fix wouldn't even be enough, since printers would need more memory to buffer the entire image rather than just reconstituting it one row of blocks at a time. There's also the added testing expense. Phones and cameras don't generate progressive JPEGs, so printer, TV, etc. manufacturers don't have any real incentive to support them. The manufacturers probably don't even write their own firmware; they contract it out.
Progressive JPEGs are nice for displaying big images in browsers over slow links (which my 1500/368 DSL qualifies as). I admit that they're easier for me in that context. But given the confusion this is causing, and that it requires non-trivial knowledge (and tools) for people to fix after the fact, I'd argue that this should be revisited.
________________________________________ From: gimp-developer-list on behalf of Michael Schumacher Sent: 31 January 2016 20:31
Robert Krawitz
***  MIT Engineers   A Proud Tradition   http://mitathletics.com  ***
Member of the League for Programming Freedom  --  http://ProgFree.org
Project lead for Gutenprint   --    http://gimp-print.sourceforge.net
"Linux doesn't dictate how I work, I dictate how Linux works."
--Eric Crampton
