Export to JPEG dialog: setting default subsampling
Export to JPEG dialog: setting default subsampling wwp 16 Jan 16:23
  Export to JPEG dialog: setting default subsampling wwp 16 Jan 18:53
   Export to JPEG dialog: setting default subsampling wwp 01 Feb 16:57
wwp
2016-01-16 16:23:04 UTC (over 9 years ago)
Hello there,
(using Gimp 2.8.14 in Linux)
Once, I've set the default JPEG export options to use the 4:4:4 subsampling value: I've set the export to JPEG dialog options to what I wanted then clicked the "save defaults" button.
When I export images to JPEG, I notice that the factory value is proposed (4:4:2 horizontal) in the dialog, instead of the default value I've set, other settings do respect my wishes. Is this behaviour expected?
FYI, the 'use quality settings from original image' checkbox is unset here, and clicking the "load defaults" does set the expected 4:4:4 value.
wwp
wwp
2016-01-16 18:53:52 UTC (over 9 years ago)
Hmm it seems to be: https://bugzilla.gnome.org/show_bug.cgi?id=747054, sorry for the noise!
wwp
wwp
2016-02-01 16:57:44 UTC (about 9 years ago)
In addition to my own noise, I presume there is no other option to set the default subsampling but editing the sources?
wwp
