GEGL build fails at gegl/docs
GEGL build fails at gegl/docs scl 03 Jan 05:54
  GEGL build fails at gegl/docs Sam Gleske 03 Jan 06:20
scl
2016-01-03 05:54:26 UTC (almost 9 years ago)
I'm trying to build GEGL with Sam Gleske's Vagrant VM. The GEGL build fails at gegl/docs with the following messages:
Making all in docs make[2]: Entering directory '/home/vagrant/git/gegl/docs' GEGL_SWAP=RAM GEGL_PATH=../operations \ ../tools/operation_reference --json-db > operations.json /bin/bash: line 1: 9278 Illegal instruction GEGL_SWAP=RAM GEGL_PATH=../operations ../tools/operation_reference --json-db > operations.json
Makefile:772: recipe for target 'operations.json' failed make[2]: *** [operations.json] Error 132 make[2]: Leaving directory '/home/vagrant/git/gegl/docs' Makefile:627: recipe for target 'all-recursive' failed make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory '/home/vagrant/git/gegl' Makefile:533: recipe for target 'all' failed make: *** [all] Error 2
Having a look into tools/operation_reference doesn't give me any useful hints.
It happens with git-master as well as with commit 026bfb8, the latest successful Jenkins build.
Does anybody have an idea how to solve this?
Thank you in advance
Sam Gleske
2016-01-03 06:20:26 UTC (almost 9 years ago)
Making all in docs make[2]: Entering directory '/home/vagrant/git/gegl/docs' GEGL_SWAP=RAM GEGL_PATH=../operations \ ../tools/operation_reference --json-db > operations.json /bin/bash: line 1: 9278 Illegal instruction GEGL_SWAP=RAM GEGL_PATH=../operations ../tools/operation_reference --json-db > operations.json Makefile:772: recipe for target 'operations.json' failed make[2]: *** [operations.json] Error 132 make[2]: Leaving directory '/home/vagrant/git/gegl/docs' Makefile:627: recipe for target 'all-recursive' failed make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory '/home/vagrant/git/gegl' Makefile:533: recipe for target 'all' failed make: *** [all] Error 2
I opened an issue regarding the matter.
https://bugzilla.gnome.org/show_bug.cgi?id=760091#c2
I see there's responses so I'll have to comment back. I was able to get 026bfb8 to build inside of the VM.
