Hotkey combo for color management
9 of 9 messages available
Hotkey combo for color management C R 08 Dec 11:51
  Hotkey combo for color management Alexandre Prokoudine 08 Dec 12:06
   Hotkey combo for color management C R 08 Dec 12:10
    Hotkey combo for color management Alexandre Prokoudine 08 Dec 12:17
     Hotkey combo for color management C R 08 Dec 12:24
      Hotkey combo for color management Alexandre Prokoudine 08 Dec 12:27
       Hotkey combo for color management C R 08 Dec 12:31
      Hotkey combo for color management Alexandre Prokoudine 10 Dec 00:24
       Hotkey combo for color management C R 10 Dec 07:25
C R
2015-12-08 11:51:18 UTC (over 9 years ago)
It seems that it's assigned "C" in the combination alt-i-c, which used to be "crop to selection". Trips me up every time now.
I recommend assigning it a different value than "c", since most people I think would probably use cropping much more often than the color management dialogue.
My 2p.
-C
2015-12-08 12:06:07 UTC (over 9 years ago)
I'm looking at stock uncustomized installed copy of GIMP 2.8 right now, and there is no default shortcut for 'Crop to Selection'.
Alex
C R
2015-12-08 12:10:55 UTC (over 9 years ago)
Alt-I-C crop to selection in stock doesn't work? Because I've been using it for years. It would be astounding if I'd been using it wrong all this time. ;)
-C
On Tue, Dec 8, 2015 at 12:06 PM, Alexandre Prokoudine < alexandre.prokoudine@gmail.com> wrote:
management
dialogue.
Alex _______________________________________________ gimp-developer-list mailing list
https://mail.gnome.org/mailman/listinfo/gimp-developer-list List archives: https://mail.gnome.org/archives/gimp-developer-list
2015-12-08 12:17:09 UTC (over 9 years ago)
I don't look at the English version of UI, that explains it :)
So you mean clashing accelerators. Yes, that should be fixed.
Alex
C R
2015-12-08 12:24:16 UTC (over 9 years ago)
Thanks. :) And yes, please. :) Also, a strange behaviour: GIMP seems to remember which accelerator you used last, and will choose "crop to selection" the next time you hit alt-i-c. I think accelerators should always do the same thing when you hit the key combination.
If you like I will gather a list of clashing accelerators and post it here (or wherever is best).
-C
On Tue, Dec 8, 2015 at 12:17 PM, Alexandre Prokoudine < alexandre.prokoudine@gmail.com> wrote:
it
time.
2015-12-08 12:27:42 UTC (over 9 years ago)
Probably gimp-gui@ material, but should work in either list :)
Also, the change will only happen in Git master, because it would invalidate existing translations.
Alex
C R
2015-12-08 12:31:03 UTC (over 9 years ago)
That's fine. It's not crippling, just annoying. I'll probably assign a hotkey to it for my own purposes for now.
On Tue, Dec 8, 2015 at 12:27 PM, Alexandre Prokoudine < alexandre.prokoudine@gmail.com> wrote:
here
2015-12-10 00:24:05 UTC (over 9 years ago)
https://git.gnome.org/browse/gimp/commit/?id=e9dd77e072d2947c8b80b5570e0337d8603a0fca
Enjoy :)
Alex
C R
2015-12-10 07:25:58 UTC (over 9 years ago)
Thanks Alex!
-C
On Thu, Dec 10, 2015 at 12:24 AM, Alexandre Prokoudine < alexandre.prokoudine@gmail.com> wrote:
here
Enjoy :)
