Segment fault on jpeg export
Segment fault on jpeg export Helmut Jarausch 25 Oct 17:20
Helmut Jarausch
2015-10-25 17:20:35 UTC (over 9 years ago)
having just updated Gimp to the current GIT-version I get a segment fault when I try to export to jpeg file. Here is what I get
gimp_display_shell_profile_update src_profile: GIMP built-in sRGB
src_format: R'G'B'A u8
dest_format: R'G'B'A u8
(gimp:26773): GLib-GObject-WARNING **: /var/tmp/portage/dev-libs/glib-2.44.1-r1/work/glib-2.44.1/gobject/gsignal.c:2569: instance '0x36c43c0' has no handler with id '68852' opened thumbnail at 160 x 120
/usr/lib64/gimp/2.0/plug-ins/file-jpeg: fatal error: Segmentation fault /usr/lib64/gimp/2.0/plug-ins/file-jpeg (pid:26958): [E]xit, [H]alt, show [S]tack trace or [P]roceed:
Is this known?
Thanks, Helmut
