Query about Brushes and names
Query about Brushes and names Andrew Francis 10 Sep 11:09
  Query about Brushes and names Joao S. O. Bueno 10 Sep 18:54
Andrew Francis
2014-09-10 11:09:52 UTC (over 10 years ago)
Dear Sir or Madam,
I do hope my query doesn't automatically go out to all developers - I don't want to pester everyone with it! My apologies if I have done so.
I just have a query about GIMP and if it is possible to change names of brushes - the boxes that I would have expected to take input for names don't let me do so which is why I'm addressing this to developers directly.
I notice also that there is a "filter" option and wondered how a person might tag brushes with filterable options?
I attached an image with a couple of screenshots added in case I am not being clear - I don't know the names for the 'bits' and am just starting as a gimp user.
Thanking you in advance for any advice you may be able to offer me,
Andrew Francis
Joao S. O. Bueno
2014-09-10 18:54:50 UTC (over 10 years ago)
On 10 September 2014 08:09, Andrew Francis wrote:
Dear Sir or Madam,
So - indeed, it is an UI issue -GIMP currently don't distinguish between resources, including brushes, which are marked as read only (either in the file system, or just marked as from a folder made read-only in the preferences). So, brush names for new brushes should be changeable - but to change the name of brushes that ship with GIMP you have to move then to a user writable location, and make the proper changes in the Brush folders page in the preferences.
Maybe you are mistaking the brush name for brush tags? Please take a look at the documentation and check if that is the case:
http://docs.gimp.org/en/gimp-tagging.html
The mail list does not accept attached files - if I had not addressed your issues correctly, please post your image somewhere on the web and send us the link.
Also, you can try e-mailing the user list instead of here - there should be more people willing to help with day-to-day using issues than here.
Andrew Francis ____________
