Jenkins: mypaint brush builds are failing
Jenkins: mypaint brush builds are failing scl 20 Jul 05:42
  Jenkins: mypaint brush builds are failing Martin Renold 20 Jul 07:11
   Jenkins: mypaint brush builds are failing scl 20 Jul 09:26
    Jenkins: mypaint brush builds are failing Jehan Pagès 21 Jul 14:07
    Jenkins: mypaint brush builds are failing Jon Nordby 21 Jul 14:49
  [SOLVED] Jenkins: mypaint brush builds are failing scl 26 Jul 14:02
scl
2014-07-20 05:42:49 UTC (almost 11 years ago)
since 13.07. the MyPaint brush build has been breaking.
Latest changes: https://build.gimp.org/job/gimp-distcheck-mypaint-brush/21/
Console output: https://build.gimp.org/job/gimp-distcheck-mypaint-brush/21/consoleFull
Latest committer to that branch, please fix.
If it's something that needs configuration changes on Jenkins, then just let me know so I can update the configuration.
Kind regards,
Martin Renold
2014-07-20 07:11:45 UTC (almost 11 years ago)
hi
I don't know where GIMP gets its libmypaint from. But it's probably just a matter of running "scons" in the libmypaint directory, to update the generated headerfiles.
Regards Martin
Kind regards,
Sven _______________________________________________ gimp-developer-list mailing list
scl
2014-07-20 09:26:22 UTC (almost 11 years ago)
Hi Martin,
thank you for your hint.
I get our libmypaint version from git://gitorious.org/mypaint/libmypaint.git
Where and when is such a scons call required - at every checkout, in our Makefiles?
Which parameters does scons need to do this?
Kind regards,
Jehan Pagès
2014-07-21 14:07:45 UTC (over 10 years ago)
To be accurate, you must run: scons enable_gegl=true install
If you forget the enable_gegl option, GIMP won't compile.
Hi Martin,
That's the right place.
Where: inside the libmypaint root directory.
When: each time you update the said libmypaint repository. Also you don't have anymore to embed the libmypaint repo inside the GIMP repo. I have contributed to upstream libmypaint to fix their installation, and Mitch has just merged my commit into GIMP's mypaint-brush branch to correctly use the third-party installed libmypaint. So just install libmypaint into the chosen prefix, and you should not have to reinstall it every time you pull GIMP.
$ scons enable_gegl=true install
Add a prefix= if you use particular prefixes. Ex:
$ scons enable_gegl=true prefix=/home/jehan/.local install
Have fun.
Jehan
Kind regards,
Jon Nordby
2014-07-21 14:49:41 UTC (over 10 years ago)
Hi Martin,
Use https://github.com/mypaint/libmypaint.git instead. Possibly the floating-point branch.
Jon Nordby - www.jonnor.com
scl
2014-07-26 14:02:15 UTC (over 10 years ago)
the mypaint-brush branch builds on Jenkins again. I've updated the configuration to work with the new libmypaint place.
Additionally the Mypaint-Brush job page https://build.gimp.org/job/gimp-distcheck-mypaint-brush/ contains a link to the libmypaint repository now.
Kind regards
