Q about gimp 2.8.12
Q about gimp 2.8.12 kungfu07 07 Jul 11:22
  Q about gimp 2.8.12 scl 07 Jul 18:17
kungfu07
2014-07-07 11:22:12 UTC (almost 11 years ago)
Q about gimp 2.8.12
Hello GIMP Development Team; it's been years that i'm a GIMP user, First *thank you enormously* for your good work in the creation of this wonderful software.
Then I want to know when you go to launch the new version 2.8.12 ? and how close is the release of GIMP 2.10 ?
Have a nice day, and keep going on your great work ;-)
-- View this message in context: http://gimp.1065349.n5.nabble.com/Q-about-gimp-2-8-12-tp43090.html Sent from the Developers mailing list archive at Nabble.com.
scl
2014-07-07 18:17:24 UTC (almost 11 years ago)
Q about gimp 2.8.12
Hi Kungfu07,
thank you for your positive feedback ;-)
From my point of view it looks as follows: I'm just finishing the last parts of the OS X integration that are meant to go into version 2.8.12. This means - reviewing a patch for the critical and urgent [bug 730211], - checking the JHBuild configuration for updates and - cleaning up.
Until this is finished I suggest we also take the time for final tests in the gimp-2-8 branch.
From my point of view we could release then.
BTW: To support the release process I shared a search in Bugzilla to quickly find the fixed bugs in this release. It's named 'GIMP - changes since last release' and GIMP developers find it in the footer of their Bugzilla sites. Currently it finds 65 fixed bugs.
I would also have loved to integrate Simone's port to her forked and updated GTK-Mac-Integration project, but as we're already late with 2.8.12 and her changes are sort of fundamental, I tend to start with that right after the 2.8.12 release. So we'll have enough time to test and do justice to it.
> and how > close is the release of GIMP 2.10 ?
There are some things yet to do whereof the GEGL port is the most important of it. We don't have a date for GIMP 2.10. Help is welcome.
Kind regards,
[bug 730211] http://bugzilla.gnome.org/show_bug.cgi?id=730211
