rle compression
rle compression Gallaher, Shane 30 Jun 11:40
  rle compression Liam R E Quin 30 Jun 20:12
Gallaher, Shane
2014-06-30 11:40:54 UTC (almost 11 years ago)
rle compression
When I go to save (v2.6) or export (2.8) an image in BMP format I am
never offered the rle compression option to do so. I need to create bmp images
Shane Gallaher
Electrical Engineer
Terex Materials Processing
Drumquin Road, Omagh
Co Tyrone
BT78 5PN
T +44 (0) 28 8224 8609 F +44 (0) 28 8224 4294
E shane.gallaher@terex.com
www.terex.com
THIS TRANSMISSION AND THE INFORMATION CONTAINED HEREIN IS CONFIDENTIAL AND IS INTENDED ONLY FOR YOUR USE. If you are not the addressee, any review, use, dissemination, distribution or copying of this transmission or its contents is strictly prohibited
Liam R E Quin
2014-06-30 20:12:51 UTC (almost 11 years ago)
rle compression
I think Run-length encoding is only suppoted for certain image types - greyscale and maybe also Indexed RGB, but not RGB.
Liam
Ankh: irc.sorcery.net irc.gnome.org www.advogato.org
