XCF format specification
XCF format specification scl 17 Jun 18:36
  XCF format specification Michael Schumacher 17 Jun 22:41
   XCF format specification Alexandre Prokoudine 17 Jun 23:10
scl
2014-06-17 18:36:03 UTC (almost 11 years ago)
in order to fix [bug 730211] I came across the [XCF file format specification]. While the XCF format has been in production use for years the spec is still marked as draft.
Which parts of the spec have become mandatory in between? What do we need to clarify that still justifies the draft state?
Kind regards,
[bug 730211]: https://bugzilla.gnome.org/show_bug.cgi?id=730211
[XCF file format specification]: https://git.gnome.org/browse/gimp/plain/devel-docs/xcf.txt?h=gimp-2-8
2014-06-17 22:41:20 UTC (almost 11 years ago)
The document has been created because someone (iirc a third party) considered "it is undocumented to discourage use by other applications" insufficient.
I'm not sure if it ever left draft status, and it seems like others on IRC are neither.
[bug 730211]:
And we're not sure how it is going to help with that?
2014-06-17 23:10:44 UTC (almost 11 years ago)
18 июня 2014 г. 2:41 пользователь "Michael Schumacher" написал:
It was Henning Makholm, wasn't it?
http://henning.makholm.net/software
Alex
