Align Visible Layers-suggestion
Align Visible Layers-suggestion Lunife Art 26 May 14:02
Lunife Art
2014-05-26 14:02:31 UTC (almost 11 years ago)
Regarding Image->Align Visible Layers window.Could transforming the 2 checkboxes,(Ignore the bottom layer even if visible,Use the(invisible) bottom layer as the base) into radio buttons, be more logic?If both checkboxes are clicked then it means that the bottom layer would not be moved and at the same time it would be used as the base for the transformation instead of the image canvas.But by using the bottom layer as the base for the transformation,dosen't that imply that it would not be moved from it's current pozition,meaning that clicking ignore bottom layer when Use the bottom layer as the base is already clicked, has no effect?And because it has no effect,i see no reason to keep it checked,so replacing checkboxes with radio buttons makes it more logic.
