GIMP requires the GEGL operation "gegl:over".
3 of 4 messages available
827805481.29695.13811340202... 09 Oct 15:23
  GIMP requires the GEGL operation "gegl:over". Adi Spivak 07 Oct 08:23
   GIMP requires the GEGL operation "gegl:over". Michael Natterer 09 Oct 15:30
    GIMP requires the GEGL operation "gegl:over". Adi Spivak 10 Oct 08:34
Adi Spivak
2013-10-07 08:23:15 UTC (over 11 years ago)
please add me in the reply to as i am not part of the DG.
i am compiling from source using git. i compile babl,gegl and gimp from git repositories. for the last 5 compile i get this error on concole: (gimp:11790): GEGL-gegl-operations.c-WARNING **: Adding GeglChantinvert-linear_c shadows GeglChantinvert_c for operation gegl:invert
and then this popup:
GEGL operation missing! GIMP requires the GEGL operation "gegl:over". This operation cannot be found. Check your GEGL install and ensure it has been compiled with any dependencies required for GIMP.
i cannot find a solution to this in google. can you help?
Adi Spivak
IT Manager
17 HaYetzira St, "Mordot HaCarmel" Industrial Park, Yokneam Elite
Mail: P.O Box 687, Yokneam 20692. Israel
TelFax.: (+972) 48-290-124. (+972) 48-290-100
www.fit-pc.com
www.compulab.co.il
Michael Natterer
2013-10-09 15:30:58 UTC (over 11 years ago)
Remove all installed GEGL operations, do a git clean -xdf in the gegl source tree, then rebuild and install.
--Mitch
Adi Spivak
2013-10-10 08:34:37 UTC (over 11 years ago)
i just found the solution and it is a really strange one. i have a softlink from /usr/bin/gimp to /usr/bin/gimp-2.9 when i run gimp i get the gegl error, when i run gimp-2.9 i don't.
----- Original Message ----- | From: "Michael Natterer"
| To: "Adi Spivak"
| Cc: gimp-developer-list@gnome.org
| Sent: Wednesday, October 9, 2013 6:30:58 PM | Subject: Re: [Gimp-developer] GIMP requires the GEGL operation "gegl:over". |
| On 10/07/2013 10:23 AM, Adi Spivak wrote: | > please add me in the reply to as i am not part of the DG. | >
| > i am compiling from source using git. | > i compile babl,gegl and gimp from git repositories. | > for the last 5 compile i get this error on concole: | > (gimp:11790): GEGL-gegl-operations.c-WARNING **: Adding | > GeglChantinvert-linear_c shadows GeglChantinvert_c for operation | > gegl:invert
| > GIMP requires the GEGL operation "gegl:over". | > This operation cannot be found. Check your | > GEGL install and ensure it has been compiled | > with any dependencies required for GIMP. | >
| > i cannot find a solution to this in google. | > can you help?
| Remove all installed GEGL operations, do a git clean -xdf in | the gegl source tree, then rebuild and install. |
| --Mitch
Adi Spivak
IT Manager
www.fit-pc.com
www.compulab.co.il
