converting svg to png with black background
converting svg to png with black background Matt Becker 20 Sep 18:01
  converting svg to png with black background Matt Becker 23 Sep 22:03
  converting svg to png with black background Ofnuts 25 Sep 12:09
Matt Becker
2013-09-20 18:01:31 UTC (about 12 years ago)
not sure if this is the right mailing list, I'm trying to convert svg to png (which is working), I just need to get the background black.
Here's my scm script:
(define (svg-to-raster infile outfile
resolution
xmax
ymax)
(let* ((image (car (file-svg-load
RUN-NONINTERACTIVE
infile
resolution
(- 0 xmax)
(- 0 ymax)
0
(drawable (car (gimp-image-get-active-layer image))) )
(plug-in-autocrop RUN-NONINTERACTIVE image drawable) (gimp-file-save RUN-NONINTERACTIVE image drawable outfile outfile) (gimp-image-delete image)
I want a non-antialiased png with black background as the final result, currently background is transparent. See attached for my original svg image. It's converting fine from shell (other than black background) via:
gimp -i -b '( svg-to-raster "special_areas.svg" "special_areas.png" 72 0 0)' -b '(gimp-quit 0)'
thanks
Matt Becker
2013-09-23 22:03:48 UTC (about 12 years ago)
resolution
xmax
ymax)
RUN-NONINTERACTIVE infile
resolution
(- 0 xmax)
(- 0 ymax)
0
I need a non-antialiased png with black background as the final result, currently background is transparent. See attached for my original svg image. It's converting fine from shell (other than black background) via:
thanks
2013-09-25 12:09:19 UTC (about 12 years ago)
resolution
xmax
ymax)
(let* ((image (car (file-svg-load RUN-NONINTERACTIVE infile
resolution
(- 0 xmax)
(- 0 ymax)
0
Completely different solution;
Use gimp-vectors-import-from-file to import a path form a SVG, then create a layer, fill with black, and stroke the path after setting the foreground to the color of your choice. However this will get your something antialiased. The same without anti-aliasing: stroke the path on a transparent layer, then threshold the alpha channel.
Improvement on your solution:
- Once you have the path on the transparent layer, alpha lock the layer and bucket fill with the final color - Inset black layer below.
