Memory can not be released
Memory can not be released 史龙 12 Sep 07:21
  Memory can not be released Daniel Sabo 12 Sep 22:10
史龙
2013-09-12 07:21:02 UTC (over 11 years ago)
Hi,all
When I call the following function, my memory will rapidly increase.Can not be released after the call is completed.Please help me diagnose.Thank you very much.
void processXmlData(const char *pXmlData) {
GeglNode *node1 = NULL;
GeglNode *node2 = NULL;
GeglNode *node3 = NULL;
GeglBuffer *buffer = NULL;
double progress = 0;
node1 = gegl_node_new_from_xml (pXmlData, NULL); node2 = gegl_node_new_child (node1, "operation", "gegl:convert-format", "format", "B'aG'aR'aA u8", NULL); node3 = gegl_node_new_child (node1, "operation", "gegl:buffer-sink", "buffer", &buffer, NULL); gegl_node_link_many (node1, node2, node3, NULL);
GeglProcessor *processor = gegl_node_new_processor (node3, NULL); while (gegl_processor_work (processor, &progress)) {
g_object_unref (processor); g_object_unref (node2);
g_object_unref (node3);
g_object_unref (node1);
g_object_unref(buffer);
Thanks
Daniel Sabo
2013-09-12 22:10:51 UTC (over 11 years ago)
What do you mean by "can not be released"? You shouldn't unref node2 and node3 because gegl_node_new_child gives the only reference to the parent node (node1 in this case), but if something is leaking after you free processor, node1 and buffer that would be a bug.
On Thu, Sep 12, 2013 at 12:21 AM, 史龙 wrote:
Hi,all
NULL);
"buffer", &buffer,
NULL);
Thanks
_______________________________________________ gegl-developer-list mailing list
gegl-developer-list@gnome.org
https://mail.gnome.org/mailman/listinfo/gegl-developer-list
