Nightly Build of GIMP
Nightly Build of GIMP Jehan Pagès 11 Sep 04:55
  Nightly Build of GIMP Michael Henning 11 Sep 23:31
   Nightly Build of GIMP Jehan Pagès 12 Sep 00:42
Jehan Pagès
2013-09-11 04:55:45 UTC (over 11 years ago)
Hello people!
Who takes care of the Nightly dev builds of GIMP here: http://nightly.darkrefraction.com/gimp/ ?
I see we link this page on the official download page, so I guess that's someone from the team.
I'd like to know what versions of libpng and cairo are used for these builds. Are these binaries taken from another project or self-built? Which exact version? With which build options?
A user reported consistent crashes on Windows 7 32-bit, both for the master and gimp-2-8 nightbuilds, on simple resize/move events (Bug 707653 ). On Windows 7 64-bit running these 32-bit binaries, I could reproduce very bad drawing bugs with the same binaries (no crash, but the user crash happens on expose events in his traces, so I think that's the same problem).
But I could not reproduce this with my own Windows builds, both for master and gimp-2-8. After some tests, I see that the problem comes from cairo and/or libpng (basically I can take my own libpng15-15.dll and copy over libcairo-2.dll to the nightbuild prefix, and it would work).
But I could not reproduce by recompiling myself libpng-1.6.3 and cairo-1.12.14. So I am wondering if the problem does not simply come from somehow broken dll in the nightbuilds. Thus I'd like to know how these have been build, which version, etc. Thanks.
Jehan
Michael Henning
2013-09-11 23:31:58 UTC (over 11 years ago)
Jehan:
These are my nightly builds. I build all of gimp's dependencies every night from source. Right now I use cairo 1.12.14, and libpng 1.6.3. All of the build options can be found around here: https://git.gnome.org/browse/gimp/tree/build/windows/jhbuild/build.jhbuildrc#n133
This definitely sounds more like a cairo problem than a libpng problem. I just realized that there's a minor upgrade of pixman available (to 0.30.2), so I'll pull that in tonight because it might have a bugfix.
I'm now cc'd on the bugreport you mentioned. We can continue this discussion there.
-- drawoc
On Wed, Sep 11, 2013 at 12:55 AM, Jehan Pags wrote:
Hello people!
Jehan
Jehan Pagès
2013-09-12 00:42:29 UTC (over 11 years ago)
thanks, I'll try to recompile cairo with these options and see if I can reproduce the crash.
Note that the crash is fixed by just changing the cairo and libpng dll (initially I had to change libpng because I tested with older versions, but now I could try only by changing cairo indeed), so I don't think that pixman may be the cause. But of course you may try. There may be some unexpected side-effect; we never know. Anyway yes let's continue on the tracker from now on!
Jehan
On Thu, Sep 12, 2013 at 11:31 AM, Michael Henning wrote:
Jehan:
-- drawoc
On Wed, Sep 11, 2013 at 12:55 AM, Jehan Pagès wrote:
Hello people!
Jehan
