(no subject)
(no subject) christopher.draper93 22 Aug 15:54
  (no subject) scl 24 Aug 08:37
  (no subject) Alexandre Prokoudine 24 Aug 09:17
2013-08-22 15:54:04 UTC (over 11 years ago)
(no subject)
Is there a way to do symmetrical drawings? Like getting a code or plug in or something?
scl
2013-08-24 08:37:50 UTC (over 11 years ago)
(no subject)
On 22.08.2013 at 05:54 P.M., christopher.draper93 wrote: > Is there a way to do symmetrical drawings? Like getting a code or plug in
or something?
[MyPaint] has symmetric drawing support.
In GIMP: I don't know of it as a built-in feature or plug-in in GIMP, but you can achieve it with some steps: 1. optionally: add a guide for the symmetry axis (Image/Guides/etc.) 2. Paint with a dark color onto a lighter or transparent canvas. 3. Duplicate the layer.
4. In case you used a non-transparent canvas in step 2: set the upper layers layer mode to 'Darken only'.
5. Flip the upper layer with the Flip tool.
If your symmetry axis is centered to the image, then you're done ;-) Otherwise:
6. If your guide from step 1 isn't in the horizontal or vertical center of the image, move the upper layer with the Move tool to its desired position or use the Align tool to align the upper layer centered to the guide.
Kind regards,
[MyPaint]: http://www.davidrevoy.com/article154/mypaint-1-1-a-guide-through-the-new-features
2013-08-24 09:17:30 UTC (over 11 years ago)
(no subject)
Not at the moment, sorry.
Alexandre
