select by opacity
select by opacity Josh Coppersmith-Heaven 20 Aug 11:12
  select by opacity scl 20 Aug 17:06
  select by opacity Ofnuts 20 Aug 17:52
2013-08-20 11:12:26 UTC (over 11 years ago)
select by opacity
hi all,
here is a simple idea, which would be very useful in certain situations... on the 'select by colour' or 'select by contiguous region' tool, it would be GREAT if there was a further option to select on the basis of opacity, from 0 - 100, within a given region....
thanks very much
josh
scl
2013-08-20 17:06:36 UTC (over 11 years ago)
select by opacity
On 20.08.2013 at 01:12 P.M., Josh Coppersmith-Heaven wrote: > it would be GREAT if there was a further option to select
I know it's not that simple as an extra option in these both tools dialogs, but does the following help you?:
1. In the Layers dialog right-click on that particular layer, select 'Alpha to Selection'.
2. Press Q to show the quick mask.
3. Use the Threshold Tool and play with the black and white triangle sliders to set the range -> this affects the selection. 4. Press Q again to hide the quick mask.
Kind regards,
2013-08-20 17:52:01 UTC (over 11 years ago)
select by opacity
On 08/20/2013 01:12 PM, Josh Coppersmith-Heaven wrote:
hi all,
Isn't that exactly what "Layer/Transparency/Alpha to selection" is all about?
