Python source code for the smooth curve through points algorithm I made
3 of 4 messages available
Python source code for the smooth curve through points algorithm I made Ben Thurston 17 Jul 07:24
  Python source code for the smooth curve through points algorithm I made Ofnuts 17 Jul 08:18
   CAGTPW+4Msz+TmdY68-WUew9Jtm... 18 Jul 00:53
    Python source code for the smooth curve through points algorithm I made Ofnuts 18 Jul 00:51
Ben Thurston
2013-07-17 07:24:37 UTC (over 12 years ago)
I made an implementation of the idea I had for the drawing of smooth curves through given points...
http://benpaulthurstonblog.blogspot.com/2013/07/smooth-curve-generator-implemented-in.html
2013-07-17 08:18:37 UTC (over 12 years ago)
The curve doesn't include the two end points and it seems it doesn't even get through one of the points (next before last at top right):
http://i.imgur.com/Hmy1DMG.png
http://benpaulthurstonblog.blogspot.com/2013/07/smooth-curve-generator-implemented-in.html _______________________________________________
2013-07-18 00:51:30 UTC (over 12 years ago)
A Bezier curve will be a lot smoother: http://i.imgur.com/73Lhvhw.png
On 07/17/2013 03:47 PM, Ben Thurston wrote:
Right I should have made it more clear, I left it as a comment in the code, but the first and last point figure into the calculation and do have some effect but are not directly connected to the rest of the curve. They could be left undrawn or automatically be selected as the top left of the bounding rectangle and the bottom right or as I was saying put anywhere to give the beginning and end of the curve the "feel" that it was coming from a certain direction before the points that actually are all connected.
The second issue is that I was placing the red dots in gimp and reading off their coordinates also with gimp to put in the program, so it wasn't exact, but the coordinates actually put in the program are all plotted as pixels so in the end are drawn as part of the curve... Thanks for the question I'm going to post this in an update with your name if you don't mind? You didn't seem to last time...
_______________________________________________ gimp-developer-list mailing list List address: gimp-developer-list@gnome.org
List membership:
