Adobe software issues
Adobe software issues Margaret Brown 08 May 04:24
  Adobe software issues Elle Stone 08 May 12:26
   Adobe software issues Guillermo Espertino (Gez) 08 May 14:36
    Adobe software issues Clayton Walker 08 May 18:22
     Adobe software issues Elle Stone 08 May 19:37
Margaret Brown
2013-05-08 04:24:10 UTC (almost 12 years ago)
Hi
With Adobe withdrawing to the Cloud, there is a real need for GIMP to include a raw file developer that can act as a replacement for Adobe Camera Raw.
If such an application could be produced and kept up-to-date when new cameras are released, we would be happy to support it and make it the default converter for our camera and lens tests. We would also be prepared to promote it through our magazine and website.
With a growing number of photographers protesting against Adobe's announcements, the time is ripe for making GIMP the favoured image editor worldwide. But this can't happen until it gets good (and timely) raw file support.
Kind regards
Margaret Brown
Technical Editor
Photo Review Australia
www.photoreview.com.au
Elle Stone
2013-05-08 12:26:09 UTC (almost 12 years ago)
This isn't a direct reply to your question, as you are asking whether Gimp itself can or will handle raw processing and I'm not sure when/whether the Gimp developers intend to go that direction. But there are two alternative approaches already being used by many people who use Gimp:
First, at least two open source raw processors have plugins to allow use with Gimp:
http://photivo.org/photivo/download_and_setup/gimp http://ufraw.sourceforge.net/Install.html
Second, Raw Therapee (and no doubt most other open source raw processors) allow the possibility of setting things up so that the processed image is automatically sent to Gimp:
http://www.rawtherapee.com/
Almost all raw processors (proprietary and open source) use dcraw to decode (but not to process) the raw images. So when dcraw adds support for a new camera, the various raw processors also update their code, usually very quickly in git/subversion/etc, more slowly in terms of an actual new release.
If you need immediate support for a new camera that is not yet supported by your chosen raw processor, dcraw (command line) can be used to process the image (it's easier than you might think, even if you don't usually use the command line).
Even if a new camera isn't yet supported officially by dcraw, usually you can decode it using the "-o 0" option to output raw color, in which case you would need to create and apply a custom camera input profile. The list of currently supported cameras is here:
http://www.cybercom.net/~dcoffin/dcraw/
and if you read the faqs (same page), you'll find suggestions for getting a new camera supported more quickly than might happen if you just wait until the camera winds its way through the usual channels.
The default ACR settings result in an image that has been made "prettier" by application of a default black point, added contrast, an S-curve, and some saturation, sharpening, noise removal, etc. The open source "gui" raw processors (UFRaw, Photivo, RawTherapee, etc) all have their own default "prettier" settings, but you probably would want to experiment to find the settings that are prettier to you. dcraw is a pure raw processor, that is, it doesn't do any "prettifying" post-interpolation image processing, so the results will look flat until you add your own curves, saturation, etc.
Kind regards, Elle Stone
On 5/8/13, Margaret Brown wrote:
Hi
Kind regards
Margaret Brown
Technical Editor
http://ninedegreesbelow.com - articles on open source digital photography
2013-05-08 14:36:34 UTC (almost 12 years ago)
El 08/05/13 09:26, Elle Stone escribi:
I'd add Darktable (www.dartable.org) to the list. It's awesome although it's not available for windows, just Linux and OSX.
The aforementioned programs are specialized tools for RAW processing and can be used in conjunction with GIMP, pretty much like Adobe Photoshop uses Adobe Camera Raw as a gateway instead of offering tools for processing RAW directly in Photoshop.
Clayton Walker
2013-05-08 18:22:06 UTC (almost 12 years ago)
Considering the fact that Adobe even has a separate program called Adobe Camera Raw, I don't see why gimp should necessarily include a raw loader. Perhaps maintainers could bundle gimp with ufraw, but to combine the two projects makes little sense.
Perhaps ufraw could be displayed more prominently on the gimp website? AFAIK, it supports higher the high bit-depth loading in gimp-2.9.
On Wed, May 8, 2013 at 8:36 AM, Guillermo Espertino (Gez) < gespertino@gmail.com> wrote:
http://photivo.org/photivo/**download_and_setup/gimp http://ufraw.sourceforge.net/**Install.html
http://www.cybercom.net/~**dcoffin/dcraw/
______________________________**_________________ gimp-developer-list mailing list
gimp-developer-list@gnome.org
https://mail.gnome.org/**mailman/listinfo/gimp-**developer-list
Please note that this signature is licensed under the General Public
License. By embedding the signature, or parts of it, into your brain other
than by mere aggregation, your brain becomes a combined, and therefore
derived, work and thus must be licensed under the GPL too.
Elle Stone
2013-05-08 19:37:46 UTC (almost 12 years ago)
The thing is, ACR is packaged as an integral part of Photoshop (or was, haven't seen any recent versions of Photoshop), and it's extremely convenient to use from within Photoshop. If you hang around the Luminous Landscape forums, you'll often find people mentioning that this or that raw processor is "much better than ACR", but they only use the "good" raw processor for really important images because ACR is quick and convenient.
It might be the case that the stand-alone raw processors with Gimp plugins and/or the automatic "send to Gimp" feature would go a long way towards offsetting the "ACR is so convenient" factor. Also batch-processing is an option. But not being familiar with the OP's workflow and time constraints, it's hard to say what might work. Most of us can be very resistant to changing how we do things!
It seems to me that dcraw and UFRaw are considerably faster and/or simpler to use than some of the other alternatives. I didn't mention Rawstudio, but it also seems suited for a very fast-paced workflow. Also, which raw processor would work the best depends on whether the OP wants to use DCP (RawTherapee, RawStudio) or ICC (they all support ICC) camera input profiles.
I agree that adding raw processing to Gimp itself (as opposed to plugins/export options) seems superfluous given the excellent quality and diversity of the existing open source raw processors.
As an aside, Darktable allows for exporting 32-bit floating point openexr images, which Gimp 2.9 can open, so with Darktable + Gimp you can stay at 32-bit floating point without the need to output to a lower bit depth before importing to Gimp.
