Bug report for ID64917
Bug report for ID64917 Sashi Kumar 04 Apr 11:54
  Bug report for ID64917 Mukund Sivaraman 11 Apr 08:34
   Bug report for ID64917 Mukund Sivaraman 11 Apr 08:50
    Bug report for ID64917 Sashi Kumar 11 Apr 10:54
     Bug report for ID64917 Mukund Sivaraman 11 Apr 11:12
      Bug report for ID64917 Sashi Kumar 11 Apr 11:52
Sashi Kumar
2013-04-04 11:54:34 UTC (about 12 years ago)
This is the bug report for https://bugzilla.gnome.org/show_bug.cgi?id=649172
The bug is that g_markup_unescape_text() does not unescape the HTML characters. This is the problem while opening the .map file. Also this is not dependent on the format(map type) of the map file.
My patch in comment #3 is wrong. As I mentioned in comment #5 the patch in comment #2 is not precise since it did not satisfy many testcases. So I will explain the problems in that.
When I tried with input: "sample entity : &sash; ' " The expected output should be: "sample entity : &sash; ' " But the result was: "sample ent ty : &sash; ' "
The exact problem is with "strcpy(p, p + strlen(tab[i].enc)-1);" To prove that, I made couple of simple codes using 'strcpy' and user-defined 'strcopy' The output of these two shows the problem.
/* test1.c */ #include
#include
#include
int main ()
gchar input[] = "sample entity";
gchar *p = input;
printf ("\n%s\n", input);
strcpy (p, p + 1);
return 0;
[sashi@SashiPC ~]$ gcc -Wall -g -o test1 test1.c $(pkg-config --cflags --libs glib-2.0)
[sashi@SashiPC ~]$ ./test1
sample entity
ample eentity
/* test2.c */ #include
#include
#include
gchar* strcopy (gchar *dest, gchar *src);
int main () {
gchar *p = input;
strcopy (p, p + 1);
return 0;
gchar *
gchar *src)
gchar *d = dest;
gchar *s = src;
do
*d++ = *s;
while (*s++ != '\0');
return d - 1;
} [sashi@SashiPC ~]$ gcc -Wall -g -o test2 test2.c $(pkg-config --cflags --libs glib-2.0)
[sashi@SashiPC ~]$ ./test2
sample entity
ample entity
So the Expected Patch is:
--- imap_csim.y.old 2013-04-04 00:17:15.564849250 +0530 +++ imap_csim.y 2013-04-04 15:40:43.693297813 +0530 @@ -38,6 +38,9 @@
extern int csim_lex(void);
extern int csim_restart(FILE *csim_in); static void csim_error(char* s);
+static gchar* unescape_text(gchar *); +static gchar* strcopy (gchar *dest, gchar *src); +
static enum {UNDEFINED, RECTANGLE, CIRCLE, POLYGON} current_type; static Object_t *current_object;
@@ -260,7 +263,7 @@
if (current_type == UNDEFINED) { g_strreplace(&_map_info->default_url, $3); } else {
- object_set_url(current_object, $3); + object_set_url(current_object, unescape_text($3)); }
g_free ($3);
@@ -280,42 +283,42 @@
alt_tag : ALT '=' STRING {
- object_set_comment(current_object, $3); + object_set_comment(current_object, unescape_text($3)); g_free ($3);
target_tag : TARGET '=' STRING {
- object_set_target(current_object, $3); + object_set_target(current_object, unescape_text($3)); g_free ($3);
onmouseover_tag : ONMOUSEOVER '=' STRING {
- object_set_mouse_over(current_object, $3); + object_set_mouse_over(current_object, unescape_text($3)); g_free ($3);
onmouseout_tag : ONMOUSEOUT '=' STRING {
- object_set_mouse_out(current_object, $3); + object_set_mouse_out(current_object, unescape_text($3)); g_free ($3);
onfocus_tag : ONFOCUS '=' STRING {
- object_set_focus(current_object, $3); + object_set_focus(current_object, unescape_text($3)); g_free ($3);
onblur_tag : ONBLUR '=' STRING {
- object_set_blur(current_object, $3); + object_set_blur(current_object, unescape_text($3)); g_free ($3);
@@ -347,3 +350,53 @@
return status;
+static gchar*
+unescape_text (gchar *input)
+ * We "unescape" simple things "in place", knowing that unescaped strings always are
+ * shorter than the original input. + *
+ * It is a shame there is no g_markup_unescape_text() function, but instead you have
+ * to create a full GMarkupParser/Context. + */
+ struct token {
+ const char *enc, unenc;
+ const struct token tab[] = {
+ size_t i;
+ for (i = 0; i < sizeof(tab)/sizeof(tab[0]); i++) { + char *p;
+ for (p = strstr(input, tab[i].enc); p != NULL; p = strstr(p, tab[i].enc)) { + *p++ = tab[i].unenc;
+ strcopy(p, p + strlen(tab[i].enc)-1); + if (*p == 0)
+ break;
+ return input;
+static gchar*
+strcopy (gchar *dest,
+ gchar *src)
+ gchar *d = dest;
+ gchar *s = src;
+ do
+ *d++ = *s;
+ while (*s++ != '\0');
+ return d - 1;
This patch works good :)
Mukund Sivaraman
2013-04-11 08:34:19 UTC (about 12 years ago)
Hi Sashi
I'm going to commit the patch in comment #7 (modified from the patch in comment #2) and push it. Thank you for reviewing the patch.
Two things you can do:
* An unrelated crash happens when alt="" is present in a map file, during load. Can you check what causes it and propose a fix?
* Please propose a fix for UTF-8 un-escaping.
Mukund
Mukund Sivaraman
2013-04-11 08:50:04 UTC (about 12 years ago)
One more thing:
* Do the other parsers (NCSA and CERN) also need unescaping?
Please can you check and make patches for these? You can open new bugs for these to track them.
Mukund
Sashi Kumar
2013-04-11 10:54:29 UTC (about 12 years ago)
Yeah, I already started working on it. It is due to double free. This crash can be avoided if MALLOC_CHECK_ environment variable is set to 0. But anyhow I will try to produce a fix in the code for this.
I will start that soon.
One more thing:
As far as I checked till now, they don't need unescaping because they don't write the HTML encodings. CSIM only needs unescaping.
Mukund Sivaraman
2013-04-11 11:12:30 UTC (about 12 years ago)
Hi Sashi
As you probably understand too, updating MALLOC_CHECK_ is neither a fix nor a workaround. :)
The checking exists to catch such errors, and updating this environment variable will only turn off the checking, but it will not stop the buggy code from being executed.
Nod.
One more thing:
Super. Thank you for checking. :)
Mukund
Sashi Kumar
2013-04-11 11:52:19 UTC (about 12 years ago)
crash
That's right :) I will try to fix :)
Nod.
One more thing:
don't
yw :)
