how can i write gegl plugin ? or http://developer.gimp.org too old
how can i write gegl plugin ? or http://developer.gimp.org too old Miroslav Talasek 12 Feb 20:37
  how can i write gegl plugin ? or http://developer.gimp.org too old Alexandre Prokoudine 12 Feb 21:34
   how can i write gegl plugin ? or http://developer.gimp.org too old Michael Henning 13 Feb 00:21
  how can i write gegl plugin ? or http://developer.gimp.org too old scl 16 May 19:32
Miroslav Talasek
2013-02-12 20:37:59 UTC (about 12 years ago)
Hi i like gimp i use only it.
I want to write alpha matting. I know that gegl library contain alpha matting from Jan Ruegg but it is still only in gegl (one year or more). I want to write plugin with two combo boxes (image and trimap selection) which call matting from gegl, but i cant find anything recent help/doc/tutorial.
This is the way to hell, http://developer.gimp.org is too old so how new developers start with gimp ? Where is recent doc to plugin api (with gegl) ? I want but i cant :(
Miroslav Talasek
2013-02-12 21:34:05 UTC (about 12 years ago)
Simply put, there is none yet. GEGL-based GIMP plug-ins are a novelty, and as a small team we don't have the manpower to update dev documentation all that often.
What you can do is:
1) study what changes have been applied to the plug-ins that we ported to use GeglBuffer, e.g.
http://git.gnome.org/browse/gimp/commit/plug-ins/common?id=07107fe214feaebf42dfa129fa3681c1e7b9bfd8 2) ask us questions on IRC.
Michael Henning
2013-02-13 00:21:55 UTC (about 12 years ago)
In addition to what Alexandre suggested, take a look at plug-ins/common/goat-exercise.c
It's a simple example of how to use gegl from within a gimp plugin.
Also, a lot of the new functions do have some reference documentation, which I think can be built if you pass --enable-gtk-doc to autogen.
Good luck.
-- drawoc
What you can do is:
gimp-developer-list@gnome.org
scl
2013-05-16 19:32:26 UTC (almost 12 years ago)
Hi Miroslav,
sorry for this late answer, I didn't see your question just now. However I decided to answer as this answer might be interesting to other potential contributors.
For help on GEGL porting: http://wiki.gimp.org/index.php/Hacking:Porting_filters_to_GEGL For help on writing plugins:
http://wiki.gimp.org/index.php/Hacking:Plugins
+ if you need direct help, the channels #gimp and #gegl on irc.gimp.org are your friends.
I hope this helps. Kind regards,
