multithreading and GEGL
19 of 19 messages available
multithreading and GEGL Alexander Rabtchevich 28 Jan 18:27
  multithreading and GEGL Victor Oliveira 28 Jan 23:37
   multithreading and GEGL Alexander Rabtchevich 29 Jan 03:24
    multithreading and GEGL Victor Oliveira 29 Jan 12:38
     multithreading and GEGL Paka 29 Jan 13:31
      multithreading and GEGL Victor Oliveira 29 Jan 17:32
       multithreading and GEGL Paka 29 Jan 17:57
        multithreading and GEGL Victor Oliveira 29 Jan 19:34
         multithreading and GEGL Paka 29 Jan 22:10
          multithreading and GEGL Liam R E Quin 29 Jan 23:11
           multithreading and GEGL Paka 29 Jan 23:23
          multithreading and GEGL Victor Oliveira 29 Jan 23:30
           multithreading and GEGL Paka 29 Jan 23:53
            multithreading and GEGL Victor Oliveira 30 Jan 16:56
       multithreading and GEGL Partha Bagchi 01 Feb 22:10
        multithreading and GEGL Victor Oliveira 02 Feb 00:30
         multithreading and GEGL Partha Bagchi 02 Feb 01:10
          multithreading and GEGL Victor Oliveira 02 Feb 01:46
           multithreading and GEGL Partha Bagchi 02 Feb 01:51
2013-01-28 18:27:40 UTC (over 12 years ago)
Hello
Is there a way to make 2.9 git master to use more than one core? Changing in GIMP settings doesn't make effect.
With respect, Alexander Rabtchevich
Victor Oliveira
2013-01-28 23:37:06 UTC (over 12 years ago)
You could try the OpenCL support in GEGL, it should use all of your cores.
ps: there are bugs still, but I'm solving them.
Victor
On Mon, Jan 28, 2013 at 4:27 PM, Alexander Rabtchevich wrote:
Hello
gimp-developer-list@gnome.org
2013-01-29 03:24:42 UTC (over 12 years ago)
I have embedded AMD 4290 graphics, which does not support OpenCL. So trying ENABLE_OPENCL=yes doesn't make any difference. And the processor is 6-cores Phenom II 1075T.
Victor
Hello
Victor Oliveira
2013-01-29 12:38:07 UTC (over 12 years ago)
You can use OpenCL in the CPU, just install the AMD OpenCL SDK. GEGL looks for libOpenCL.so in /usr/lib.
You should use GEGL_ENABLE_OPENCL=yes
Victor
Hello
Paka
2013-01-29 13:31:21 UTC (over 12 years ago)
* Victor Oliveira [01-29-13 07:39]:
export as environment varible or ??
tks,
(paka)Patrick Shanahan       Plainfield, Indiana, USA      HOG # US1244711
http://wahoo.no-ip.org        Photo Album: http://wahoo.no-ip.org/gallery2
http://en.opensuse.org                           openSUSE Community Member
Victor Oliveira
2013-01-29 17:32:26 UTC (over 12 years ago)
yes,
export GEGL_ENABLE_OPENCL=yes
also, when you build GEGL, put the option --enable-config. with that you can set:
export GEGL_DEBUG=opencl
so you can see if OpenCL is really being used or if there is some bug.
Victor
tks, --
(paka)Patrick Shanahan Plainfield, Indiana, USA HOG # US1244711 http://wahoo.no-ip.org Photo Album: http://wahoo.no-ip.org/gallery2 http://en.opensuse.org openSUSE Community Member Registered Linux User #207535 @ http://linuxcounter.net _______________________________________________ gimp-developer-list mailing list
Paka
2013-01-29 17:57:19 UTC (over 12 years ago)
* Victor Oliveira [01-29-13 12:34]:
yes,
tks, I added to ~/.bashrc as I use pre-packaged rpm. I cannot see that opencl is required or used by gimp, as rpm -q gimp --requires
does not show opencl
is there a test to show usage other than dis-abling, timing an action, and enabling and timing same action?
tks,
Victor Oliveira
2013-01-29 19:34:41 UTC (over 12 years ago)
no, besides building gegl by yourself, no. GIMP doesn't require OpenCL because the libOpenCL.so is loaded at runtime (like, dlopen) in the case it is present at the machine.
Victor
yes,
tks, --
Paka
2013-01-29 22:10:17 UTC (over 12 years ago)
* Victor Oliveira [01-29-13 14:35]:
Then I guess the gimp package on my system does not utilize opencl. I opened gimp and loaded an image, instructed gimp to use GEGL and performed a GEGL operation on the photo. psaux does not reveal any opencl process or library being loaded.
Or is my thinking flawed?
tks,
Liam R E Quin
2013-01-29 23:11:56 UTC (over 12 years ago)
You'd more likely need to use strace to see if the library was opened; I am not sure that anything would show up in ps in this case.
Liam
Paka
2013-01-29 23:23:09 UTC (over 12 years ago)
* Liam R E Quin [01-29-13 18:12]:
tks,
ran strace -o gimp
opened image enabled GEGL under video
enabled GEGL under colors
performed tools->gegl-operation->noise-reduction closed image/gimp
did grep -i opencl got no hits
so I do not have opencl compiled in gimp
I am using proprietary NVidia drivers, 310-19, and have support installed for opencl and can confirm that darktable uses it.
Does this appear correct?
Victor Oliveira
2013-01-29 23:30:24 UTC (over 12 years ago)
It should work on GIMP 2.8.2. Do you have libOpenCL.so? Also, I'm not sure if it spawn a separated process.
If you continue to have problems, I suggest you to build GEGL.
Victor
tks, --
Paka
2013-01-29 23:53:50 UTC (over 12 years ago)
* Victor Oliveira [01-29-13 18:49]:
/usr/lib/libnvidia-opencl.so.1
/usr/lib/libnvidia-opencl.so.310.32
/usr/lib64/libnvidia-opencl.so.1
/usr/lib64/libnvidia-opencl.so.310.32
provided by proprietary NVidia driver 310.32
I do not see problems but was wondering if OpenCL was being utilized and so far, I would say not. My i7/12gb/GTS-450 should benefit.
tks,
Victor Oliveira
2013-01-30 16:56:34 UTC (over 12 years ago)
that's strange, because it looks for the exact name "libOpenCL.so", don't you have it? It should be installed with the driver. But probably you have it considering that you can use darktable without problems.
I have also a nvidia GPU with GIMP-2.8 (from Ubuntu 12.10) and noise-reduction works fine with the GPU.
victorm@Brava:~$ export GEGL_USE_OPENCL=yes victorm@Brava:~$ gimp-2.8
Victor
tks, --
Partha Bagchi
2013-02-01 22:10:45 UTC (over 12 years ago)
Victor,
When I look at the code, I don't understand how you are handling the Mac OS, when you don't typically see so libraries, by dylibs. Can you elaborate?
Also, when I try to add --enable-config to configure, I get configure: WARNING: unrecognized options: --enable-config
Thanks, Partha
On Tue, Jan 29, 2013 at 12:32 PM, Victor Oliveira wrote:
yes,
Victor
tks, --
US1244711
Member
Victor Oliveira
2013-02-02 00:30:01 UTC (over 12 years ago)
Hello Partha.
I'm sorry, I mean "--enable-debug" instead of "--enable-config".
That's a good observation. In Windows I look for "OpenCL.dll" and in Linux I look for "libOpenCL.so", but I'm not sure how I should handle it in MacOS. I was assuming it was the same as the Linux way. Do you know how I should do this?
Victor
On Fri, Feb 1, 2013 at 8:10 PM, Partha Bagchi wrote:
Victor,
Thanks, Partha
yes,
Victor
tks, --
Partha Bagchi
2013-02-02 01:10:29 UTC (over 12 years ago)
Hi Victor,
I think on Windows for 32-bit you are OK with call OpenCL.dll, but I think you need to call OpenCL64.dll for 64-bit?
For Mac, according to http://developer.apple.com/library/mac/documentation/Performance/Conceptual/OpenCL_MacProgGuide/OpenCL_MacProgGuide.pdf
the sample code on page 17, says:
// This include pulls in everything you need to develop with OpenCL on OS X v10.7.
#include
To compile from the command line, I think you need to do have -framework OpenCL during compilation.
For instance,
gcc -framework OpenCL filein.c -o filein
Can we test this out?
Thanks, Partha
On Fri, Feb 1, 2013 at 7:30 PM, Victor Oliveira wrote:
Hello Partha.
Victor
Victor,
OS,
Thanks, Partha
On Tue, Jan 29, 2013 at 12:32 PM, Victor Oliveira <
victormatheus@gmail.com>
wrote:
yes,
Victor
tks, --
Victor Oliveira
2013-02-02 01:46:49 UTC (over 12 years ago)
On Fri, Feb 1, 2013 at 11:10 PM, Partha Bagchi wrote:
Hi Victor,
I have a 64-bit Windows system and it comes with OpenCL.dll.
#include
For instance,
The problem is, I don't have a machine with MacOS :/
Thanks,
Partha
Hello Partha.
Victor
Victor,
Thanks, Partha
wrote:
yes,
Victor
tks, --
Partha Bagchi
2013-02-02 01:51:44 UTC (over 12 years ago)
Hi Victor,
think
OK, I could be wrong, but I have an nvidia card on my windows machine and seem to remember seeing opencl64.dll. I don't have it handy this weekend, but I will check when I am back on that machine.
OS X
v10.7.
#include
For instance,
I do. :) Happy to test out any code you want me to.
Thanks,
Partha
wrote:
Hello Partha.
Victor
wrote:
Victor,
Mac
OS,
elaborate?
Thanks, Partha
wrote:
yes,
bug.
Victor
GEGL
tks, --
Community
Member
