building git on SuSE 12.2
10 of 10 messages available
building git on SuSE 12.2 Dexter Filmore 22 Oct 14:52
  building git on SuSE 12.2 Jon Nordby 22 Oct 16:00
   building git on SuSE 12.2 Dexter Filmore 22 Oct 19:15
   building git on SuSE 12.2 Dexter Filmore 22 Oct 19:17
    building git on SuSE 12.2 Dexter Filmore 22 Oct 20:04
     building git on SuSE 12.2 Chris Mohler 22 Oct 20:31
     building git on SuSE 12.2 Michael Schumacher 22 Oct 20:34
      building git on SuSE 12.2 - gtk-doc added, but... Dexter Filmore 23 Oct 01:22
       building git on SuSE 12.2 - gtk-doc added, but... Gfxuser 23 Oct 18:55
     building git on SuSE 12.2 Jon Nordby 22 Oct 20:46
Dexter Filmore
2012-10-22 14:52:17 UTC (over 12 years ago)
Hi all,
I made some futile attempts to build git on SuSE 12.2 but as soon as I try and build gegl it claims that babl (which I just built and pointed autogen for gegl at) does not exist.
So far I hacked up some scripts, the babl script for example looks like this:
#!/bin/bash export PATH=/opt/gimp-git/bin:$PATH
export PKG_CONFIG_PATH=/opt/gimp-git/lib/pkgconfig export LD_LIBRARY_PATH=/opt/gimp-git/lib export ACLOCAL_FLAGS="-I /opt/gimp-git/share/aclocal $ACLOCAL_FLAGS" export XDG_DATA_DIRS=/opt/gimp-git/share
cd babl ./autogen.sh --prefix=/opt/gimp-git && make
which then results in babl being installed in /opt/gimp-git
After that I call gegl.sh:
cd gegl ./autogen.sh --prefix=/opt/gimp-git && make
....which returns:
checking for BABL... no configure: error: Package requirements (babl >= 0.1.10) were not met:
No package 'babl' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you installed software in a non-standard prefix.
Alternatively, you may set the environment variables BABL_CFLAGS and BABL_LIBS to avoid the need to call pkg-config. See the pkg-config man page for more details.
Pointers appreciated.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GCS d--(+)@ s-:+ a C++++ UL++ P+>++ L+++>++++ E-- W++ N o? K-
w--(---) !O M+ V- PS+ PE Y++ PGP t++(---)@ 5 X+(++) R+(++) tv--(+)@
b++(+++) DI+++ D- G++ e* h>++ r* y?
------END GEEK CODE BLOCK------
Jon Nordby
2012-10-22 16:00:23 UTC (over 12 years ago)
On 22 October 2012 16:52, Dexter Filmore wrote:
Hi all,
Not unless you also run "make install"? ;) If that is not the problem, check that "babl.pc" ends up in the expected directory ($libdir/pkgconfig) and that PKG_CONFIG_PATH is set accordingly.
Dexter Filmore
2012-10-22 19:15:35 UTC (over 12 years ago)
Am Monday 22 October 2012 18:00:23 schrieb Jon Nordby:
Hi all,
#!/bin/bash
Ahem, of course I ran make install :}
Found babl-pc in /opt/gimp-git/lib64/pkgconfig:
dexter@shodan:/opt/gimp-git/lib64/pkgconfig$ cat babl.pc prefix=/opt/gimp-git
exec_prefix=${prefix}
libdir=${exec_prefix}/lib64
includedir=${prefix}/include
Name: babl Description: Dynamic, any to any, pixel format conversion library Version: 0.1.11
Cflags: -I${includedir}/babl-0.1
Libs: -L${libdir} -lbabl-0.1 -lm
When I check on PKG_CONFIG_PATH from console, it is empty. I think that's the problem, but I'm not that deep into the field that I'm sure. Could be some gtk devel files are missing. gtk2-devel is there, but I wouldn't know what else I need.
Dexter Filmore
2012-10-22 19:17:32 UTC (over 12 years ago)
Hi all,
#!/bin/bash
I think I got it: the .pc files is in /opt/gimp-git/lib64/pkgconfig, the script does not point at lib64. I'll adapt that and retry.
Version: 3.12
Dexter Filmore
2012-10-22 20:04:24 UTC (over 12 years ago)
Am Monday 22 October 2012 21:17:32 schrieb Dexter Filmore:
Hi all,
#!/bin/bash
I now succesfully compiled babl and gegl, calling the gimp build script (which is the same but cds to the gimp src dir)
$ ./gimp.sh
I am testing that you have the tools required to build the GNU Image Manipulation Program from git. This test is not foolproof, so if anything goes wrong, see the file HACKING for more information...
checking for libtool >= 1.5 ... Major version might be too new (2.4.2) checking for gtkdocize ...
You must have gtk-doc installed to compile GNU Image Manipulation Program. Install the appropriate package for your distribution, or get the source tarball at
http://ftp.gnome.org/pub/GNOME/sources/gtk-doc/ You can also use the option --disable-gtk-doc to skip this test but then you will not be able to generate a configure script that can build the API documentation. checking for autoconf >= 2.54 ... yes (version 2.69) checking for automake >= 1.10.0 ... yes (version 1.12.1) checking for intltool >= 0.40.1 ... yes (version 0.50.2) checking for xsltproc ... yes
Please install/upgrade the missing tools and call me again.
I don't know what it wants here. xsltproc is installed, just to be sure I even pulled that one's git version and installed it:
$ /opt/gimp-git/bin/xsltproc --version Using libxml 20708, libxslt 10127-GITv1.1.27-7-gd3f3331 and libexslt 816 xsltproc was compiled against libxml 20708, libxslt 10127 and libexslt 816 libxslt 10127 was compiled against libxml 20708 libexslt 816 was compiled against libxml 20708
I don't know what else to do.
Version: 3.12
Chris Mohler
2012-10-22 20:31:03 UTC (over 12 years ago)
Looks like you need gtk-doc.
Chris
2012-10-22 20:34:48 UTC (over 12 years ago)
Do you have gtk-doc installed?
Jon Nordby
2012-10-22 20:46:00 UTC (over 12 years ago)
gtk-doc looks to be missing.
Dexter Filmore
2012-10-23 01:22:10 UTC (over 12 years ago)
Am Monday 22 October 2012 22:34:48 schrieb Michael Schumacher:
Ok, I expected the last line before the error to be the culprit and did not look further up. Heat of the battle. Installed gtk-doc and some libs that were missing, now I come as far as this:
rootme=`pwd`; \ destdir=`cd ../.. && pwd`; export destdir; \ builddir=`cd ../.. && pwd`; export builddir; \ cd . && \
PDBGEN_BACKUP=0 \
/usr/bin/perl enumcode.pl \
&& echo timestamp > $rootme/stamp-enum-code Name "Gimp::CodeGen::enums::enums" used only once: possible typo at enumcode.pl line 30.
Name "Gimp::CodeGen::util::FILE_EXT" used only once: possible typo at enumcode.pl line 33.
No changes to /home/dexter/software/gimp-git/gimp/libgimp/gimpenums.h No changes to /home/dexter/software/gimp-git/gimp/libgimp/gimpenums.c.tail make[3]: Leaving directory `/home/dexter/software/gimp-git/gimp/tools/pdbgen' make[3]: Entering directory `/home/dexter/software/gimp-git/gimp/tools' CC gimptool.o
CCLD gimptool-2.0
CC test-clipboard.o
CCLD test-clipboard
make[3]: Leaving directory `/home/dexter/software/gimp-git/gimp/tools' make[2]: Leaving directory `/home/dexter/software/gimp-git/gimp/tools' Making all in cursors
make[2]: Entering directory `/home/dexter/software/gimp-git/gimp/cursors' GEN tool-cursors.list
GEN gimp-tool-cursors.h
failed to load "./cursor-bad.png": Couldn't recognize the image file format for file './cursor-bad.png'
make[2]: *** [gimp-tool-cursors.h] Fehler 1 make[2]: Leaving directory `/home/dexter/software/gimp-git/gimp/cursors' make[1]: *** [all-recursive] Fehler 1 make[1]: Leaving directory `/home/dexter/software/gimp-git/gimp' make: *** [all] Fehler 2
Checked on the file: dexter@shodan:~/software/gimp-git/gimp/cursors$ file cursor-bad.png cursor-bad.png: PNG image data, 36 x 36, 8-bit/color RGBA, non-interlaced
So it's there. Why does make complain?
Version: 3.12
Gfxuser
2012-10-23 18:55:16 UTC (over 12 years ago)
I lately had similar pain compiling GIMP and its dependencies. This brought me many steps further: https://staff.banu.com/~muks/tmp/gimp-build-script.txt together with http://wiki.gimp.org/index.php/Hacking:Building/Linux. Some dependencies might be missing on your system (the error you reported may come from a missing libpng development package), but ./configure or ./autogen.sh should tell you them.
Kind regards,
