SmartDeblur
10 of 10 messages available
SmartDeblur Luke Benes 22 Oct 07:14
  SmartDeblur Michael Natterer 22 Oct 13:21
   SmartDeblur SorinN 23 Oct 09:16
    SmartDeblur Guillermo Espertino (Gez) 23 Oct 10:52
     SmartDeblur SorinN 23 Oct 14:56
      SmartDeblur Kẏra 24 Jul 16:27
       SmartDeblur Alexandre Prokoudine 24 Jul 16:35
        SmartDeblur Kẏra 24 Jul 22:39
         SmartDeblur Chris Mohler 24 Jul 22:44
         SmartDeblur Alexandre Prokoudine 24 Jul 22:50
Luke Benes
2012-10-22 07:14:38 UTC (over 12 years ago)
SmartDeblur
Vladimir Yuzhikov has release his SmartDeblur program under the GPL at https://github.com/Y-Vladimir/SmartDeblur Yuzhikov worked on two common cases: blurring due to incorrect focus and blurring due to movement. "Each of you knows very well," he points out, they "are very difficult to repair." In fact, the examples used as samples by Yuzhikov are impossible to fix using current commercial technology. You can see these amazing results here:http://gizmodo.com/5953601/incredible-csi-enhance-technology-fixes-unfocused-photos If anyone has the interest to port this into the plugin system, it would make a huge addition, giving GIMP something no other editor has. -Luke
Michael Natterer
2012-10-22 13:21:12 UTC (over 12 years ago)
SmartDeblur
That looks truly impressive, but it will have to become a GEGL op, not a GIMP plug-in to be included. A GEGL op is also much more useful generally.
Is Vladimir interested in working on that?
--mitch
SorinN
2012-10-23 09:16:41 UTC (over 12 years ago)
SmartDeblur
We already have a plugin which ca do something similar in GIMP (and is standing as a gimp plugin for quite a while ..). Now this plugin seems to be unmaintained. please check here : http://refocus-it.sourceforge.net/
I've just compiled refocus-it and I can say I have very good results similar with examples on their website
the point is that refocus-it is quite slow and not easy to set - but once you got the right values - the result looks magic
I feel that Vladimir put the accent on "easy to use" else the concept / procedure / result look similar.
2012/10/22 Michael Natterer :
--mitch
gimp-developer-list@gnome.org
2012-10-23 10:52:33 UTC (over 12 years ago)
SmartDeblur
El 23/10/12 06:16, SorinN escribi:
SoriN: Does Refocus work for motion blur too? As far as I could see it was very good but only for out-of-focus pictures, not for motion blur. Also defocus does, in my opinion, a very poor work when the image has an alpha channel. It tends to introduce noticeable artifacts around the edges.
Gez.
SorinN
2012-10-23 14:56:00 UTC (over 12 years ago)
SmartDeblur
I don't know yet but I will try ..and I will let you know there is a control who allow you to indicate the direction of the motion ( that mean you manually approximate the motion - there is not an automated procedure for autodetection of length or degree of the motion )
thank to the measure tool in GIMP you can check those things quite accurate ( if the image is not too blurry )
2012/10/23 Guillermo Espertino (Gez) :
Gez.
Kẏra
2014-07-24 16:27:31 UTC (over 10 years ago)
SmartDeblur
SorinN gmail.com> writes:
2012/10/23 Guillermo Espertino (Gez) gmail.com>:
I found this thread via Google and I was wondering whether any progress was made. It looks like refocus-it hasn't been updated in a year and a half and I was wondering if whether anything was found that dealt with motion blur.
This definitely seems like a high-value project for GIMP. Is there a wishlist item, or bug report that exists or could be made to track interest and development?
Outside of GIMP, does something like SmartDeblur exist anywhere as free software for GNU/Linux?
Thank you so much! Kẏra
gimp-developer-list gnome.org
2014-07-24 16:35:40 UTC (over 10 years ago)
SmartDeblur
You mean, like the original SmartDeblur app written in Qt? :)
Alex
Kẏra
2014-07-24 22:39:10 UTC (over 10 years ago)
SmartDeblur
Alexandre Prokoudine gmail.com> writes:
Win and OSX only, but either way I already tried it through wine and it barely worked.
Chris Mohler
2014-07-24 22:44:26 UTC (over 10 years ago)
SmartDeblur
Never tried it, but : http://rglinuxtech.com/?p=538
Chris
2014-07-24 22:50:51 UTC (over 10 years ago)
SmartDeblur
Win and OSX only
https://github.com/Y-Vladimir/SmartDeblur/issues/7
I must've faked that screenshot, right? :)
Alex
