Links to other languages
Links to other languages Roman Joost 16 Oct 04:37
  Links to other languages Ulf-D. Ehlert 17 Oct 18:00
   Links to other languages Roman Joost 19 Oct 04:01
    Links to other languages Ulf-D. Ehlert 19 Oct 18:40
     Links to other languages Roman Joost 04 Dec 03:44
     Links to other languages Roman Joost 05 Dec 03:24
Roman Joost
2012-10-16 04:37:55 UTC (over 12 years ago)
I'm currently working on a branch to fix #168256 (https://bugzilla.gnome.org/show_bug.cgi?id=168256) to have a small menu which links to corresponding translations.
I've change the current build temporarily to deploy the new menu under docs.gimp.org. It should be slighlty hidden on the top hand corner. Currently it is not build by default to avoid leaking into the help browser. The disadvantage of the current approach is, that the menu is rendered at 'compile time' not being aware of any other deployed translations.
I was wondering if I could get some feedback about it. Would it make sense to add an option to the configure script, or rather leave it of hidden in the build process as it is currently.
Who's interested; build the langage of your choice with:
XSLTEXTRAFLAGS="--stringparam gimp.help.languageselector 1" make html
Cheers,
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
Ulf-D. Ehlert
2012-10-17 18:00:12 UTC (over 12 years ago)
Hmm, bugzilla has a strange sense of humour: Reported: 2005-02-23
Last reply: 2006-01-10
Status: NEW
Why is this a problem?
If it works and we are all happy with this feature, it would be a pity if we'd hide it. Adding a configure option (with default="disabled"?) would make sense IMO.
I did, and it looks promising. The menu is hard to read, but this can be fixed with a proper CSS entry.
It looks that I have found a minor bug:
I tried it with ALL_LINGUAS="en de fr" and got a menu with 2 entries ("English Deutsch") for all 3 languages. Just had a quick look at the stylesheet: it seems that your tokenizer failes (last tail ["fr"] does not contain $splitstr).
Ulf
Ich finde es nicht nur schner, sondern auch
ntzlicher, meinem Hund zu folgen als der Obrigkeit.
		-- Karlheinz Deschner
gimp-docs-list mailing list
gimp-docs-list@gnome.org
Roman Joost
2012-10-19 04:01:32 UTC (over 12 years ago)
Hi Ulf,
Status: NEW
Hah yes - this one is in the database for ages :)
What is built does not necessarily end up on the server.
Yes - I thought the same. I'll add a configure option.
Cheers!
Yes. I kept it that way to be able to test it on docs.gimp.org. I'll change the CSS to make it more useful.
Eeek! Cheers for that!
Thanks!
Roman Joost
Ulf-D. Ehlert
2012-10-19 18:40:07 UTC (over 12 years ago)
But how many new languages do you add every year? ;-)
There's another simple bug I found when I was playing with CSS: "" should be replaced with "", since "id" must be unique.
I have attached a patch with my changes.
Ulf
Die guten Christen sind am gefährlichsten - man verwechselt
sie mit dem Christentum.
Roman Joost
2012-12-04 03:44:22 UTC (over 12 years ago)
Hi Ulf,
sorry didn't mean to stop posting, but real life can be interrupting ;) I actually had this reply lying around for weeks until I got a chance to finish it :(
Ok ok. Thanks for the heads up :)
Cheers! Of course!
Thanks for the patch. That is excellent! Looks you fixed the problems you pointed out.
Cheers,
Roman Joost
Roman Joost
2012-12-05 03:24:26 UTC (over 12 years ago)
Hi Ulf,
I've included your patch and merged the changes with master. I also added a configure option ('--enable-languageMenu') to build the HTML with a language selector. The option is off by default.
Thanks a lot for your feedback and help.
Cheers,
Roman Joost
