Buffer Overflow Study at Auburn University - GIMP developers I would really appreciate your help!
Buffer Overflow Study at Auburn University - GIMP developers I would really appreciate your help! Auburn Study 14 Oct 07:39
Auburn Study
2012-10-14 07:39:16 UTC (over 12 years ago)
Hi All,
I am a graduate student at Auburn University, working with Dr. Munawar Hafiz on an empirical study project to understand the software engineering practices used in companies that produce secure software. In particular, we are concentrating on how developers write code to prevent buffer overflow and integer overflow vulnerabilities. We are interested in the software development process: how you develop software, how you test and analyze programs to detect vulnerabilities, and what processes you follow to remove bugs. We are looking into automated tools that software developers use, and are expecting that there is a common insight in the security engineering process that can be reusable.
We request your assistance by participating in this research study. We would greatly appreciate it if you would share your experience with us by answering the questions at the end of this email. We may send some follow up questions based on your response in future. Your response(s) will be kept confidential, and will only be aggregated with those of other reporters. Please let us know if you have any questions or concerns regarding the study. Thanks in advance for your support.
Yasmeen Rawajfih Software Analysis, Transformations and Security Group Auburn University
Working under the supervision of: Dr. Munawar Hafiz
Assistant Professor
Dept. of Computer Science and Software Engineering Auburn University
Auburn, AL
http://munawarhafiz.com/
Questions: (There are ten questions.)
1. How long have you been a software developer?
2. How long have you been affiliated with GIMP? Were you part of the original development team for this software?
3. What is the size of the current code base?
4. Did you follow a coding standard when developing this software? Is it a standard determined by your group?
5. What did you use to manage bug reports in your software? Does it satisfy your requirements? Are there other software options that you would consider switching to?
6. Did you use any compiler options to detect integer overflow vulnerabilities? Do you think that they are useful?
7. Did you use any automated (static or dynamic analysis) tools to detect buffer overflows, integer overflows, or any other bugs? Which tools did you use? Why these tools?
8. Did you use fuzzing? Which tools did you use and why? If you wrote your own fuzzer, why did you write it yourself? Was it written from scratch or by extending some other fuzzing tools?
9. Did you have specific phases during development where you concentrated on fixing security issues? Did you have a test suite, unit tests, or regression tests?
10. Buffer overflows often result from the use of unsafe functions, such as strcpy. Does your software use those? If you use a different string library, why is it used? Is it an in-house library or an off-the-shelf library? Did you migrate your code to use the string library?
