GIMP's ICM simulation must be improved as PhotoShop
GIMP's ICM simulation must be improved as PhotoShop ndummy001@yahoo.co.jp 23 Sep 07:28
  GIMP's ICM simulation must be improved as PhotoShop scl 23 Sep 08:12
   GIMP's ICM simulation must be improved as PhotoShop Elle Stone 23 Sep 22:11
    GIMP's ICM simulation must be improved as PhotoShop Guillermo Espertino (Gez) 23 Sep 22:28
     GIMP's ICM simulation must be improved as PhotoShop Alexandre Prokoudine 23 Sep 22:33
      GIMP's ICM simulation must be improved as PhotoShop Guillermo Espertino (Gez) 23 Sep 22:36
2012-09-23 07:28:19 UTC (over 12 years ago)
GIMP(win) has some color management features on settings dialog. But it's not enough( e.g. black point calibration ) Developers must implement these if you all truly thinking that GIMP is important.
scl
2012-09-23 08:12:49 UTC (over 12 years ago)
I agree with you, that color management is a very important part to make GIMP a high-end photo manipulation application as written in the product vision. Many users and developers share that opinion. You could for instance read the postings of Elle Stone and yvind Kols a.k.a. pippin to see the ongoing efforts on this topic. As you can see, the GIMP team takes this topic seriously.
The settings dialog is not the only part where you find color management in GIMP. Have you already looked at the Image/Mode/Assign Color Profile... and Image/Mode/Convert to Color Profile... menu items? Particularly the latter contains the desired black point compensation. Also check View/Display Filters..., move there the 'Color proof' filter to the right list and click it. It give you a proof view of the image and its options also contain Black point compensation.
I think it's a mistake to judge from one part to the whole. At least 16K users only at Google+ don't share your opinion (to say it with Alexandre ;-) and not all GIMP users are on G+.
Kind regards,
gimp-developer-list@gnome.org
Elle Stone
2012-09-23 22:11:48 UTC (over 12 years ago)
I agree with what you say about the color management settings dialog. Neither the Gimp Display settings nor the Softproof settings provide the user with the very important choice of whether to use or not to use black point compensation.
Also, Gimp display rendering intent (and probably the softproof rendering intent, but I haven't checked) gives different results for "relative colorimetric" and "perceptual", even when the destination profile is a matrix profile (the more usual case for monitor profiles).
The problem is, matrix profiles don't support perceptual intent: perceptual intent requires a lookup table and matrix profiles don't have lookup tables. As matrix profiles don't support perceptual intent, having "perceptual intent" and "relative colorimetric" give different results means a coding decision was made at some point in the past.
In the lcms.c code, I found the following lines:
if (config) intent = config->display_intent; else
intent = GIMP_COLOR_RENDERING_INTENT_PERCEPTUAL;
bpc = (intent == GIMP_COLOR_RENDERING_INTENT_RELATIVE_COLORIMETRIC);
which means that in Gimp, for your display profile, "relative colorimetric intent" is hard-coded to give you "relative colorimetric intent with black point compensation," and "perceptual intent" gives you "without black point compensation".
Which gives you a partial workaround for the missing user option of being able to choose "with or without black point compensation". If you are using a matrix profile as your monitor profile, you really can choose whether or not to use black point compensation, albeit in a totally non-intuitive way. But if you are using a lut display profile with a perceptual intent table and a relative colorimetric intent table, you are stuck with "without black point compensation" if you choose "perceptual intent" and you are stuck with "with black point compensation" if you choose "relative colorimetric intent".
(As an aside, if you are using the V2 sRGB matrix profile as your monitor profile, along with any standard RGB working space (sRGB, BetaRGB, ClayRGB, Widegamut, etc), you won't see any difference between "relative" (which in Gimp is with black point compensation) and "perceptual" (which in Gimp is without black point compensation), because sRGB and all the other standard working spaces all have zero black points.)
Fixing the missing black point compensation option involves editing "lcms.c", "preferences-dialog.c" and probably a few other files. I would cheerfully attempt the task myself, but I think the "gui" portion is beyond my coding skills, so I would need help from someone more versed in the Gimp code.
The Image/Mode/Convert menu items does offer the option of using or not using black point compensation. But proper color management requires that the same options be available for the monitor profile and for softproofing.
The Gimp Color Proof Display Filter seems to offer everything anyone would want in the way of softproofing and display options. Unfortunately, as far as I can tell from comparing the results to other image editors (Cinepaint, Krita), the Gimp Color Proof Display Filter doesn't work properly.
Kind regards, Elle Stone
2012-09-23 22:28:20 UTC (over 12 years ago)
El 23/09/12 19:11, Elle Stone escribi:
The Gimp Color Proof Display Filter seems to offer everything anyone would want in the way of softproofing and display options. Unfortunately, as far as I can tell from comparing the results to other image editors (Cinepaint, Krita), the Gimp Color Proof Display Filter doesn't work properly. Kind regards, Elle Stone
I've used this one in 2.6 for print softproofing: Gives better results than the print preview settings in GIMP and seems to be more consistent with what I get from CMYKtool, which has a very reliable preview (at least in my experience).
I'd love to have something like this in GIMP in the future.
Gez.
2012-09-23 22:33:39 UTC (over 12 years ago)
Did you mean to link to http://registry.gimp.org/node/24944 ? :)
2012-09-23 22:36:53 UTC (over 12 years ago)
El 23/09/12 19:33, Alexandre Prokoudine escribi:
I was asking myself where I put the link and YOU HAD IT! Next time don't take my things without asking first. Thank you.
:-p
Gez.
